Clearance Items Available From ReGo Electric Conversions
*Contact Garrett: [email protected] 612-822-1626 to make an
offer.
Netgain Warp 9 Electric Motor 9" DC motor $1,360.00
Kelly Motor Controller KDH15600,156V,600A,series/PM $1,189.15
DC-DC Converter Iota 75 amp DC-DC converter 108-190VDLS-7 $253.84
Battery Charger Manzanita Micro ChargerPFC-20 $1,742.50
Vacuum Pump Kit Complete Vacuum Assist Kit w/ reservoir $329.80
Fluid Heater Kim Hotstart 120VAC/3000 Watt Coolant Tank Heater with
Thermostat $368.05
VDC Fluid Heater MES-DEA RM4 4kW 100-250 VDC 70degC $592.45
Inertia Switch INERTIA SWITCH...NC (normally closed)...5 Amps/12 VDC...
2oz RL2512 $25.50
High Voltage Fuses FERRAZ/SHAWMUT...500 Amps DC/300 VDC max $38.25
E-meter, Xantrex Xantrex Linklite $153.81
Potbox, PB6 Curtis PMC-PB6 Swing-arm...5 k Ohm with microswitch...4
ft. cable... $68.00
Shaft Speed Sensor, Zolox Zolox Motor Speed Sensor Kit DL9-2171s -
produces 4 pules per revolution $38.46
High Voltage Relay MAGNECRAFT W199 BX-12 open frame relay with blow
out magnet, 12VDC Coil, 30 Amp capacity. $35.15
Temperature Switches B501 Small Flange Cap, 90 deg Terminal Bend
100degF Close Temp, 85degF Open Temp $8.29
10degF Close Temp, 24degF Open Temp $11.05
Air Conditioning System Masterflux SIERRA05-0982Y3 Compressor,
025F0140-01 Controller, 14942832 Wire Harness, LP157 Mounting Kit
$990.60
Power Steering Pump Power Steering Pump System $696.05
LiFePO4 Batteries Thundersky 160 Ahr LiFePO4 Batteries TS-LFP160AHA
$199.00
Manzanita Lithium BMS Manzanita Digital Lithium Battery Regulators
enough for 48 cells, Relay board for high and low cells, 4' voltage
and temp harnesses $2,900.00
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101014/2d401f66/attachment.html
offer.
Thermostat $368.05
2oz RL2512 $25.50
ft. cable... $68.00
$990.60
$199.00
