In the marine industry, we used the paint on electrical tape. You can ev=
en use =
multiple layers if you think it has the potential for impact or extreme =
environmental hazard. Works great! And, a quick light slice with an exacto =
knife =
and it peels off easier than anything else I have ever used.
RW
________________________________
[email protected]>
To: Electric Vehicle Discussion List <
[email protected]>
Sent: Wed, March 9, 2011 6:31:22 PM
Subject: Re: [EVDL] Corrosion on lead-acid battery terminals
What I did, Roland, this time, beside turning the vent holes away from the =
terminals - coated the terminals and inside of the clamps with KoprKote, pu=
t =
the anit-corrosion washers on the terminals, then coat over top the clamps, =
terminals and bolts with Scotchkote, a liquid rubber coating. We'll see how =
that goes.
Joseph H. Strubhar
Web: www.gremcoinc.com
E-mail:
[email protected]
----- Original Message ----- =
[email protected]>
To: "Electric Vehicle Discussion List" <
[email protected]>
Sent: Wednesday, March 09, 2011 12:42 PM
> Hello Joe,
> I use to have these type of Trojans battery that did the same thing after =
> 8 years of usage. So when I replace the batteries, I coated new batter=
y =
> clamps and the battery post except for the battery clamp contact area wit=
h =
> that black and red tool handle rubber dip stuff. The directions on this =
> compound says it acid proof. Did not coat the battery clamp bolts, but =
> coat the space between the battery clamps bolt holes.
> I also install the red and black anti-corrosion felt rings below the =
> battery clamp and the post pad. Coat all the expose lead terminal down=
to =
> the battery top.
> I did this type of anti-corrosion installation on Sept 4, 2009 and do not =
> have and corrosion at all. While the charger is on, I do not read any =
> conductance from any of the battery post to the battery tops which I did =
> with the old batteries.
> Roland
> From: "joe" <
[email protected]>
[email protected]>
> Sent: Tuesday, March 08, 2011 6:56 AM
> Subject: [EVDL] Corrosion on lead-acid battery terminals
>> Probably I'm just slow, but I made and interesting discovery yesterday =
>> while
>> working on the battery terminal corrosion on the Datsun KingCab. I have
>> Trojan T-105's, and wondered why some positive terminals had a lot more
>> corrosion than others. Then I noticed that the caps on the cells have =
>> vent
>> holes only on one side, and I had an eppifany - if the vent holes next to
>> each terminal were turned toward the terminal, they would spray acid mist
>> directly onto the connection! Has anyone else noticed this???
>> Joseph H. Strubhar
>> E-mail:
[email protected]
>> _______________________________________________
>> | REPLYING: address your message to
[email protected] only.
>> | Multiple-address or CCed messages may be rejected.
>> | UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
>> | OTHER HELP: http://evdl.org/help/
>> | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
> | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev =
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110309/374f5eb6=
/attachment.html =
