Hello Al,
That gray or dark gray on the bottom of the caps is normal. As batteries
are charge, the sulfate SO4 is being remove from the negative plates and is
going into solution. If you charge at a very high current, this sulfate
particles will exploded off the negative plates more rapid which does not
allow time to be exchange with the H2O of the water to make more H2SO4 which
is the battery acid.
Over time, even over a slow charging, you will get this build up on the
bottom of the caps, because the batteries are still at a low simmer
bubbling, the hydrogen vents H leaving SO4 sulfate which does not vent on
the caps.
My bottom of my caps are almost black now which may even contain some oxide
from the positive plates. I was told long time ago, not to clean them,
because when they are in this condition, they may act like Hydrocells which
I had at one time. The excess gassing which releases the hydrogen may react
with this compound on the caps and it returns some of it to the cell, thus
less loss of the hydrogen and electrolyte.
About every three months after I do a equalizing charge to about 90 to 95%,
I than water the batteries and than do a finish charging for the last 10%,
so the water will better mix with the electrolyte.
My batteries which are Trogen T-145's are still perfect after six years of
running every day at a average of 5 miles a day.
The 2.6 per cell is a equalization or balance charge voltage which I do only
every 3 months or about every 500 miles. This is 7.8 volts per battery or
156 volts for a 120 volt pack.
My normal charge is at 7.5 volt per battery or 2.5 per cell at a
temperatures of 60F to 80F. Over 80F battery temperature, I drop it to
about 7.4 volts per battery.
Look at the Trojan Company Maintenance Web Site, there are charging data
tables there that will tell you the exact charging methods for these types
of batteries.
Roland
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]>
Sent: Sunday, August 12, 2007 9:39 PM
Subject: [EVDL] crud on battery caps
> I have a pack of Trojan T-125 floodies. I noticed when watering that the
> bottom of the cell caps have a thin coating of gray material on them
> (lead?)
> Is this normal or are my batteries being fried by the charger? Once, when
> the Zivan was on yellow topping up mode I read 157V across a 120V pack.
> Thats 2.6 VPC !! Is that too high?
> Thanks, Al
the caps.
of batteries.
Roland
> (lead?)
> Thanks, Al
