G'day All
Ebay finds, no connection with seller, but I've had dealings in the past
and all was OK.
Item number:130440460412 Input 36 to 72VDC, output +5V 74A, +3.3V 60A,
+12V 16A, -12V 2.5A. Don't know if its' adjustable, but these things
often are, they have two available at $13.58 each they're cheap enough.
Item number:200527984244 Input 36 to 190VDC, output +5V 100A, +12V 12A,
+12V 7A. This one is adjustable, I'm using a pair of similar ones for my
EV, unfortunately they only have one available at $29.49 cheap enough if
you can use 19A at 12V or grab it and wait until more turn up and use 3
x 5V in series for 100A plus the isolated 12v rails.
Item number:150496469067 Input 110 to 175VDC, output +12V 6A, +12V 2.5A.
This one is adjustable, but only +5% on the front panel trimmer, might
be more adjustable by getting at the board and changing fixed
components.Probably a bit dear at $49.99 for only 8.5A.
Regards
[Technik] James
and all was OK.
Regards
[Technik] James
