[EVDL] Determining whether you're subscribed to EVDL
806 Views 0 Replies 1 Participant Last post by  EVDL List
On 22 Sep 2007 at 12:14, [email protected] wrote:
> is there an easy
> way for people to check if they got unsubscribed?
Go here :
http://lists.sjsu.edu/mailman/options/ev
Enter the mail address you use for the EVDL. You'll need your password to
log in (it was in the welcome message you received when you subscribed - you
DID save that message, no? ;-). If you don't have your password, never
fear; just scroll to the bottom and click Remind. The page will tell you
that your password has been mailed to you.
If you don't have web access at that moment, instead of using the webpage
above, you can email a message with the subject
password
to the address
[email protected]
In the message body, type
end
The message must be sent from the same mail account with which you're
(supposedly) subscribed to the EVDL.
Whichever method you use, check your email for your password. It should
arrive within a minute or two.
If you DON'T receive your password, the most likely reason is that you're
NOT subscribed. (Mailman apparently doesn't check whether your address is
subscribed until AFTER it's already cheerfully told you it's mailed you your
password.) The old list manager, Listproc, returned a "You are not
subscribed" message when a nonsubscriber queried it. But Mailman is
different; if you're not subscribed and you request your password, it just
ignores you.
If you DO receive your password, use it to log in and check your
subscription settings. The top of the page will tell you what your bounce
score is (if any) and warn you if you've been suspended. Further down the
page you'll find the option to enable or disable mail delivery. It's the
first item under "Your EV Subscription Options." That's where you reset
your account if it's been disabled because of bounces.
EVDL Administrator
1 - 1 of 1 Posts
1 - 1 of 1 Posts
