[EVDL] Digital potentiometer adapter
1584 Views 2 Replies 1 Participant Last post by  EVDL List
Hi all,
Here's something which may be of interest to people still stuck using
0-5Kohm resistive potboxes!
For some conversions we're doing at EV Works, we chose controllers
which (unfortunately) only support resistive throttle inputs, but we
wanted to use the factory hall effect accelerator pedal to drive them.
So here's some information about a device I designed to interface the
two, based around a digital potentiometer:
http://www.evworks.com.au/tech/DigitalPotAdapter/
There's also a download link at the end for the schematic/PCB files
and AVR project for the microcontroller code.
Kind regards,
Ian Hooper
[email protected]
1 - 3 of 3 Posts
Nicely done, thanks for making it available!
Bear in mind though that "resistive" throttle inputs often work perfectly
well with an 0-5V signal anyway, so in that case it's enough to amplify /
level shift the hall effect signal using just analogue components.
That also has much less complexity so seemingly lower chance of it jamming
on and driving you into a tree :)
Ian Hooper <[email protected]> wrote:
> Hi all,
> Kind regards,
> Ian Hooper
> [email protected]
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110228/397a0d7f/attachment.html
On 1:59 PM, Ian Hooper wrote:
> Hi all,
There is a pin-compatible 5K version:
http://ww1.microchip.com/downloads/en/DeviceDoc/22060b.pdf
In case that matters.
... Also do be careful, they aren't exact replacements for a physical
pot. When I was
looking for one for LCD contrast control, I soon discovered they don't
like signals
outside of their supply voltage (found one exception, it took a single
+5V supply and
it could handle -5V to +5V on the pot pins).
Zachary Heilig ([email protected])
1 - 3 of 3 Posts
