I'd suggest you find a Geo Metro 5-speed transaxle,
they are small and light and can be had relatively
cheap and easy.
Jack
cheap and easy.
Jack
--- "M. Barkley" <[email protected]> wrote:
> The transaxle you propose below, is 13.25/1 in
> forward. So is this math correct: My wheels have
> to
> go 800 revolutions to travel 1 mile, Therefore
> 13.25
> x 800 = 10,600rpm for the motor if directly
> connected.
> Does this mean for the vehicle to reach 60mph, the
> motor would have to run this 10,600rpm continuously
> stay at that cruising speed?
> I ask, because I've found a donor VW, without a
> tranny, thinking of using a modified differential
> between the drive hubs and direct connect the
> electric
> motor to that differential. I'd like to see the car
> reach 80mph, with a typical cruising speed of 65 on
> the highway. So I'm trying to figure out a gear
> ratio
> to look for, that would accomplish this speed range
> for a typical dc traction motor rpm sweet spot.
> Any enlightnment on the proper math formula would be
> greatly appreciated.
> > Here ya go, transaxle :
http://www.surpluscenter.com/Item.asp?UID=2007102516472855&catname=powerTrans&item=13-1431
