[EVDL] E-Meter question
776 7
I would like to know if you should connect the 12 volt input on the E-Meter
to the switched 12 vdc or straight to the 12 volt battery?
Thanks, Freddie
http://www.austinev.org/evalbum/899
http://www.southernev.com/dakotaev.htm
1 - 8 of 8 Posts
Hello Freddie,
The E-meter 12 volt input should be un switch from any 12 volt source. If
you turn off the 12 volt to the E-meter, you will lose your data to it, just
like you have reset it.
There is a isolation module call a E-meter DC-DC converter that isolates the
12 volt input from a 12 volt battery or any other 12 volt source. You must
isolated both the positive and negative side of the 12 volt source. Some
prescalers for E-meters have this built in isolation module for a 12 volt
input.
Roland
----- Original Message -----
To: <[email protected]>
Sent: Tuesday, October 16, 2007 10:49 AM
Subject: [EVDL] E-Meter question
> E-Meter
> Thanks, Freddie
Depends on whether you have a high voltage pack, in
which case it is: neither, you have to connect the
E-meter to the *isolated* 12V supply that you use
dedicated for the E-meter, because the 12V negative
is connected to the pack negative on the E-meter,
so the entire E-meter is "hot" and you do not want
to ground your pack via your E-meter.
With either a 12V DC/DC or a cheap switching laptop
power supply for your E-meter, you have isolation to
avoid this problem.
Success,
Cor van de Water
Systems Architect
Email: [email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: [email protected]
Second Life: www.secondlife.com/?u=3b42cb3f4ae249319edb487991c30acb
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Freddie Hartsell
Sent: Tuesday, October 16, 2007 9:50 AM
To: [email protected]
I would like to know if you should connect the 12 volt input on the E-Meter to the switched 12 vdc or straight to the 12 volt battery?
Thanks, Freddie
Mine is powered off the bottom 2 batteries(24V) so it won't brown out. I
did this temporarily but it worked so well, i just left it.
Ditto with my electric boat...
Of Jeff Shanab
Sent: Thursday, October 18, 2007 9:47 PM
Subject: Re: [EVDL] E-Meter question
Discussion Starter · #7 ·
Yes, I have purchased the isolation module and I finally read the
instruction enough to find the correct answer. The meter has a sleep mode
that it will go in if I understand the instructions correctly. I was afraid
of leaving it connected and running my 12 volt battery dead.
Thanks, Freddie
Of Roland Wiench
Sent: Thursday, October 18, 2007 9:14 AM
Hello Freddie,
input.
Roland
> E-Meter
> Thanks, Freddie
It depends on how much drain you actually have with the meter and it's supply. It may be so insignificant that it hardly makes a difference.
My Saab has 6 computers, including the body computer which is on all the time. I throw a charger on every couple of weeks until I start driving itl, but it takes less than 5 minutes to fully recharge, so VERY low loss from anything I can see. You may be worried about something that is not an issue at all.
IMHO
Mark Ward
95 Saab 900 "Saabrina"
www.saabrina.blogspot.com
> Thanks, Freddie
> Of Roland Wiench
> Hello Freddie,
> input.
> Roland
> From: "Freddie Hartsell" <[email protected]>
> > E-Meter
> > Thanks, Freddie
1 - 8 of 8 Posts
