The incremental cost increase of going to 72 volts is well worth the flexibility the higher voltage gives you. You don't mention any of your design goals, so I will assume you want to be able to go just as far and as fast as possible within your budget
My experience has been that 72 volts will make those goals easier, and give you more options for tweaking things after the fact.
damon
> From: [email protected]
> Date: Tue, 31 Aug 2010 17:41:35 -0600
> To: [email protected]
> Subject: [EVDL] E-moto: 48V or 72V?
> EVDL,
> We are designing a light commuter e-moto with a little over three kWh on board using 16 Ah Headway cells. My question is whether to configure the bike as a 48V system (16S4P) or 72V (24S3P). Each option has some obvious advantages - 48V: slightly cheaper controller and BMS; 72V: smaller gage wiring. Our bike has a chain drive so we can adjust the sprocket sizing to accommodate the max speed of the motor at the different voltages.
> Am I missing something obvious in working through this decision? I apologize if this is a stupid noob question, but I've been getting different opinions on the issue from friends and colleagues I've polled.
> Thanks in advance for any help!
> Tom McKinnon
> | REPLYING: address your message to [email protected] only.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20100901/3279a5b6/attachment.html
damon
> EVDL,
> Tom McKinnon
