--- ZillaVIlla wrote:
> if the batteries were light enough, they could be
> taken out and left on the
> trailer at the staging area to charge during the
> next tour with an onsite
> diesel generator (not ideal I know but it's off the
> grid), perhaps a 2 or 4
> part pack to get the individual weight down under
> 100 lbs each. I thought
> it would be really trick to build battery poles out
> of some type of small
> cells (think of d-cell sized batteries rigged into
> shrink wrap in 4 foot
> long tubes) that could fit inside of the 1.5" frame
> tubing thus hiding the
> power source. Hide the wires inside the tubing so
> all that's partially
> exposed is a small controller box and ac motor on
> the center of the rear
> axle and you'd get asked "how's it go?" they're
> independent suspension with
> a locked rear axle which is better traction in sand
> but it also makes it so
> you have to slide to turn(they're setup to drive
> fun. there's no front
> brakes which enables you to steer during full lock
> panic stops. Ideally,
> with enough torque, you'd just have a motor with
> shafts coming out both
> sides that the CV joints could bolt right up to,
> then no more chain to mess
> with. they only use perhaps 2 gallons per tour,
> these are Honda generator
> motors which in stock form spin at 1800 rpm and make
> 24 HP, we spin them at
> around 4100 to 4400 rpm depending on how fast we
> want the top speed to be.
> we don't modify the motors we just adjust the built
> in speed governor.
> The vroom vroom is definitely an appealing draw for
> many, but not all of our
> customers. personally I like the sound of the tires
> rolling, but not the
> suspension squeaking. A speaker with a speed
> variable sound could put this
> back in the mix and it could sound however you want
> it to - perhaps like the
> flying cars on the old Jetsons cartoon show.
> I love this forum for the technical "what ifs" that
> pour through here. at
> some point battery technology will be cheap enough
> that gas won't make sense
> for this application anymore. we spend I think
> about $4,000 a week on gas
> at our Las Vegas location but that's buggies,
> shuttles, and trucks combined.
> other benefits would be to impress the BLM Bureau of
> Land Management who
> permit us to operate on this land on how
> environmentally friendly we are.
> We already send our guides out picking up trash
> everyday. People camp in
> this area and leave all kinds of junk, we get lots
> of it out just to be
> cool.
> we get perhaps 1 rollover every 2 weeks. we run
> these thing really hard but
> they're very stable and very hard to roll over.
> When they do roll, oil get
> in the wrong parts of the engine and they will not
> turn over until it's been
> pumped out of the cylinders, and the sealed lead
> acid batteries we use to
> start them don't like being upside down either.
> I believe the cost for the ICE part of the buggies
> runs about $4,000 per
> car, the frame and suspension we fabricate ourselves
> so adaption to electric
> motor mounts and position can be altered.
> Electric could also let me keep the center of
> gravity much lower thus
> improving it's resistance to rolling over and that's
> just that much safer.
> the whole appeal of these is you can drive like a
> maniac in relative safety.
> which brings me back to long skinny batteries so
> they could rest in the
> floor and be changed by pulling out from the rear of
> the car.
> thanks again for the insights.
> On 8/31/07, Roger Stockton <
[email protected]>
> wrote:
> > ZillaVIlla wrote:
> > > I currently work for a dune buggy adventure
> company in Las
> > > Vegas (gets up to 115 degrees here regularly
> during the summer)
> > > http://www.sunbuggyfunrentals.com
> > > Our Buggies are powered by 670cc Air and Oil
> Cooled V Twin
> > > motors and mostly run 2 hour long adventures on
> varied terrain
> > > uphill, downhill, sand, hard pack,rocks, and
> gravel. In their
> > > current configuration the top speed is about 50
> MPH but they
> > > rarely see over 35 MPH
> > > we have about 50 of these and are building more.
> > How many do you add to the fleet each year?
> > I think that replacing your present fleet would be
> a decent enough
> > volume to perhaps allow you to get better pricing
> on components or even
> > access to parts individual hobbiests can only
> dream about, but
> > realistically you might be looking at only
> building perhaps 10 vehicles
> > a year on an ongoing basis.
> > > Perhaps the battery pack could be changed at the
> end of each
> > > 2 hour tour and the old pack plugged into a
> charger for the
> > > next trip?
> > How much time is available between trips? The
> pictures on your site
> > suggest the buggies are carried to/from the tour
> start on a car-carrier
> > type arrangement and it might be a pain to add an
> extra unload/re-load
> > step at your base if the buggies aren't presently
> unloaded between trips
> > anyway.
> > How much time do the buggies spend on the trailer;
> might it make sense
> > to charge them while on the trailer?
> > > In the current configuration the Buggies weigh
> about 800 Lbs.
> > > I figure you'd save weight in the engine to
> motor conversion
> > > and then gain it back with your gasoline to
> battery conversion.
> > What does the present engine, CVT, and chain drive
> weigh? How much fuel
> > does the tank hold?
> > There is no doubt an electric buggy would end up
> weighing a few hundred
> > pounds more, but the basic buggy is so light that
> the
> > battery-to-curb-weight ratio should still be much
> better than most any
> > on-road EV. Performance should still be at least
> equal to the ICE
> > despite the weight, and the EV could seem more
> powerful than the ICE by
> > virtue of having better low end torque and
> smoother torque application
> > when starting.
> > > These things bounce LOTS so I don't know if it'd
> be better to
> > > go with a certain type of battery over another.
> > It would bias me toward spiral wound AGMs such as
> Optimas, if going with
> > lead acid. How often do your customers flip the
> buggies? Ultimately
> > that would be the deciding factor between using
> floodies of any sort or
> > not.
> > > Expect that each buggy would run 4 times a day
> for 2 hours each
> > > time, every day 365 days a year.
> > How much idle time between runs? How much time
> spent in transit?
> > > if they cost $13,000 to build now (we make them
> from "Scratch"),
> > > where does it become cost effective to go
> electric
> > > (initial investment VS. operating expense)?
=== message truncated ===
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
