Roland, you had a detailed procedure on connecting emeter based on the
manual.
Is there a proper procedure to disconnect the emeter?
how does this sound?
Reverse this:
"Once you completed all the wiring, insert the 12 volt fuse first and than
the battery pack fuse last!
So,
1 Disconnect the HV battery pack
2. Disconnect 12 volt power.
Then freely detach the other wires
or do I still have to disconnect other things in a certain order?
my goal being to reroute the operational Emeter wiring thru a better route.
thanks,
Ben
manual.
Reverse this:
So,
thanks,
Ben
