1 - 5 of 5 Posts
Some charging stations have the option to be just a J1772 plug, or add in a
standard 120v/20 amp (5-20) plug. Most of the ChargePoint charging stations
recently installed around the Bay Area have both. There is a third option that
is a station with just a 120v plug, but I don't think that would really be too
practical. The 120v system on any of these stations doesn't need to talk to the
car. It senses that a plug is inserted by some sort of optical device (clear
plugs won't work) before it allows power to the system.
I wonder how the J1772 adapters that are being sold work for an EV conversion
with a 240v charger?
- Tom Keenan
(snipped from the 'Washington EV Tax' thread)
> I wouldnt even doubt that the charging stations will exclude any car without
a j1772 plug in and have a bms that can talk to the charging station.
Discussion Starter · #2 ·
Works fine!!!!
http://www.tucsonev.com/darren.html
Here's a picture of one of TEVA2's members using a J1772 Inlet (with a pilot signal that he made up)
at one of the Chargepoint Charging Stations in Tucson. He has PFC-40 charger and has no problems. As
you can see in the 2nd photo his J1772 Inlet is permanently installed. At home he has a J1772 Plug
that he uses and at his workplace (TEP), is going to get some J1772 Charging Stations soon. He also
has a couple different types of Adapters so that he can opportunity charge when he needs to.
Rush Dougherty
www.TEVA2.com
www.TucsonEV.com
One of our club members (EVA/DC) with a RAV4 EV successfully charged
at a Chargepoint station using the J1772 to NEMA 14-50 adapter and his
portablized SPI charger.
Dave
> Works fine!!!!
> Rush Dougherty
> www.TEVA2.com
> www.TucsonEV.com
This weekend, one of the EBEAA members with a Volt charged up at an Avcon
station, using an adapter she made for Avcon -> J1772. Apparently works well!
Tom Keenan
----- Original Message ----
To: Electric Vehicle Discussion List <[email protected]>
Sent: Sun, February 27, 2011 9:32:02 AM
Subject: Re: [EVDL] EV Charging Stations
Dave
> Works fine!!!!
>he has a J1772 Plug
>he needs to.
> Rush Dougherty
> www.TEVA2.com
> www.TucsonEV.com
[EVDL] EV charging stations
I am at a solar industry conference in colorado and half of the electrical distributors here are touting their EV charging stations in addition to the solar products now. Several of our PV clients are having circuits for EV chargers (either charging stations or just 50a dryer plugs) run as part of the PV installation.
Z
Sent from my iPhone
"matt lacey" <[email protected]> wrote:
> Hi Chuck,
> I would suggest using an Elcon (now called TC Charger) instead.
> PF is 0.99, eff 92%
> The 3000W model backs off to 15A when running on 120vac.
> It really will put out 24A, at least until it hits the 1800W limit
> When on 240vac it will do the full 24A
> You don't have to charge fast on every charge.
> Btw - DPF = Displacement Power Factor, its a measure of how in phase the
> current and voltage waveforms are.
> PF = DPF * Harmonic Factor
> Matt
> ----- Original Message -----
> From: "Chuck Hursch" <[email protected]>
> To: "Electric Vehicle Discussion List" <[email protected]>
> Sent: Friday, February 10, 2012 6:40 AM
> Subject: Re: [EVDL] Isn't 120 V. outlet a sufficient "EVSE" ?
>> I thought maybe I should mention that 120V / 15A outlet will not be
>> sufficient to charge a "big" Pb-acid pack at sufficient charge rates.
>> For example, my pack is 96V of 6V US2200XC floodies. The A-hr capacity
>> is approximately 230 A-hr. Nawaz @ US Battery was adamant that I be
>> charging my pack at C/10, or about 23A. There is no way I can charge my
>> pack in one fell swoop at 23A. I could go about 11-12A, safely, here at
>> the apt. with my 120V/20A outlet. With my 15A AC timer gear, it is
>> about 8-9A DC into the pack, far, far from Nawaz's recommendation. So
>> one has to ask, is charge rate / density important enough to forgo the
>> 120V scene? I rather wish I had wired up 240V/208V for my carport
>> outlet, but that would've been far more expensive.
>> A better-PFC charger than my Zivan K2 would help in this regard, but
>> there are none that are isolated and will do better than the K2 to any
>> great degree.
>> On 2/1/2012 7:39 PM, Dennis Miles wrote:
>>> Below is a link (it is safe,) to an eight minute audio link you
>>> all
>>> should listen to. The speaker is from the electric and gas utility in San
>>> Diego, California. I believe it brings forth many valid points which are
>>> very disturbing about the excessively expensive charging stations we are
>>> all wasting our money on when they are simply not needed or necessary for
>>> Electric Car use. "WAKE UP AMERICA" We are being ripped off by profiteers
>>> and charlatans who are simply out to make a big profit at our expense.
>>> Will
>>> the next item be a five pound box of "Baking Soda" for $5,000 to sprinkle
>>> under your electric car if the battery leaks? (Just as useless!)
>>> http://us.evupdate.com/fc_tele_evupdatelz/lz.aspx?p1=05440502S538&CC=&p=1&cID=0&cValue=1
>>> To summarise, for charging at home, The 120 V. 15 A. outlet as
>>> is
>>> typical in the American home provides sufficient electrical power to
>>> recharge an electric car in about five hours to replace that charge used
>>> in
>>> driving up to 40 miles daily (That is 85% of American drivers.) An
>>> investment of thousands of dollars to be able to recharge from 240 V. at
>>> 50
>>> A. is superfluous. Even owners of the Tesla Sports car who paid $109,000
>>> for the car usually use only a 120 V. outlet for recharging (70% from
>>> owner's survey) because they do not, nor does any other member of the
>>> majority of electric car users feel any cost above $400 is a reasonable
>>> value for a dedicated electric outlet in their home. Thus the J1772
>>> standard level 2 is suitable for public charging stations only because it
>>> is being funded by "Grants" and is free to the users. Apparently only
>>> salesmanship and advertising or marketing hype are responsible for
>>> installation and use of the J1772 standard level 2 for recharging in
>>> private garages, carports, or other local charging locations.
>>> Perhaps a better long term solution is light rail or other medium
>>> range public transit alternatives for the daily driver who commutes more
>>> than 40 to 60 miles on a daily basis. In that way, the many citizens
>>> would
>>> be served not just the few served by a series of roadside "High Speed" DC
>>> charging stations.
>> | Moratorium on drag racing discussion is in effect.
>> | Please take those discussions elsewhere. Thanks.
>> | CONFIGURE: http://lists.sjsu.edu/mailman/listinfo/ev
>> No virus found in this message.
>> Checked by AVG - www.avg.com
>> Version: 2012.0.1901 / Virus Database: 2112/4799 - Release Date: 02/09/12
1 - 5 of 5 Posts
