Well, I just tested my mutant Sparrow on a 16 mile trip.
This Sparrow is (GASP!) carrying a little Kipor KGE3000Ti generator,
which is feeding my PFC-40 charger.
(I built a really ugly rack to carry it hanging under the back.
Pictures to make you sick will be posted soon.)
I've found that I can set the charger for about a 10-11A charge off the
genset before it starts causing problems for the generator.
On my 16 mile run (to town and back) with very few stops, I averaged
98Wh/Mile out of the battery pack. This is in comparison to the
180-200Wh/mile i've been using without the genset.
The only reason I'm doing this horrible thing is that my job is now 32
miles one way. (Yes, I can charge at work). With the genset, I'll be
able to use the bird to commute again.
What I would prefer is to find some better batteries to get the Sparrow
more range.
My 2nd choice is to find a 2 kwh or so battery block that I can use
instead of the generator. Genset weighs about 70lbs, and I wouldn't
want anything heavier than that.
more range.
