1 - 6 of 6 Posts
Discussion Starter #1
Firefly has a brochure out on its group 31 battery, and says a spec sheet will be available Dec. 1.
http://www.fireflyenergy.com/images/stories/pdfs/FFE-27Grp31BatteryBro10%5B1%5D.25.07_FINAL.pdf
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Discussion Starter #3
It's already been established in a prior post that this first gen battery is only incrementally better than regular lead acid because only one of the plates is using the carbon foam technology. I think this is a poor strategy. If they really can't make enough plates they should release fewer batteries at a higher pricepoint to showcase the performance.
----- Original Message ----
The specs contradict each other on different parts of the website. On
the brochure linked below, they site "50+ Percent Greater Cycle Life"
and then indirectly compare to "200 deep discharge cycles" of "most
lead-acid batteries. In the "white paper" they have a log scale plot
showing ~3000 cycles for Firefly technology batteries at 100% DOD.
They keep saying it is so much better, but don't give just the simple
specs for the battery itself. Not a good sign.
Discussion Starter #4
One of their earlier press releases cited deep cycle use for truckers,
running their "hotel loads," as opposed to idling.
http://www.fireflyenergy.com/index.php?option=com_content&task=view&id=44&Itemid=58
Jeff Shanab <[email protected]> wrote:
> I don't see any mention of deep cycle use. Are they going to have a
> different line or does the technology even support deep cycle usage?
Discussion Starter #6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1 - 6 of 6 Posts
