Hello Peri,
I have done about every thing except operate on other people, I let my
nephews who are Doctors do that. I started in the electrical science back
in 1944 experimenting in my father's electrical lab at his electrical
company. I built overhead electric trolley systems and a electric force
field that kept dogs out of our garden.
We had one old electrical worker which also did geophysic work back then
that actual work with Nickola Tesla on his air-ground electrical towers in
Colorado.
I then study the Geophysics sciences and built equipment which is use to
detect deposits in the earth. I also experiment with ground penetrating
radio equipment, which can determine the depth and dielectric of compounds.
During all that, its been designing and constructing EV's .
Roland
----- Original Message -----
[email protected]>
To: "'Electric Vehicle Discussion List'" <
[email protected]>
Sent: Friday, November 12, 2010 1:49 PM
Subject: Re: [EVDL] Fuel Cell sources?
> Roland, is there anything you haven't been involved in? How do you manage
> it! (rhetorical question - you don't need to answer)
> -----Original Message-----
> From:
[email protected] [mailto:
[email protected]] On
> Behalf
> Of Roland Wiench
> Sent: 12 November, 2010 1:19 PM
> To: Electric Vehicle Discussion List
> Hello Andrew,
> Fuel cells required a lot of accessory equipment to operated. You do not
> want a PEM type of fuel cell which requires a hydrogen fuel in large
> insulated pressurized tanks.
> It is best to use the AFC type which converts Anhydrous Ammonia to pure
> hydrogen for a on board mobile unit. This still takes a lot of accessory
> The Anhydrous Ammonia is very dangerous which you need a special training,
> storage facilities, permits, insurances and licenses to handle.
> Here is some data from a research company that I have been in contact
> since
> 1968. I received my first proto type EV from them in 1976. They may list
> several companies that have a license right to produce these units. I
> remember that one company was in Germany producing 5 kw units at 120 volts
> for military field use.
> http://electricauto.com/fc_prog.html
> Roland
> From: "Andrew Wood" <
[email protected]>
> To: "EVDL" <
[email protected]>
> Sent: Friday, November 12, 2010 11:45 AM
> Subject: [EVDL] Fuel Cell sources?
> > Im interested in experimenting with Hydrogen fuel cells. Is there a
> > supplier thats good to deal with or are they as difficult to get as A123
> > cells?
> > What are typical voltages and currents achievable with a cell.
> > How do they compare size/weight to power ratio to lithium cells?
> > Regards
> > Andrew
> > Sent from iPhone
> > _______________________________________________
> > | REPLYING: address your message to
[email protected] only.
> > | Multiple-address or CCed messages may be rejected.
> > | UNSUBSCRIBE: http://www.evdl.org/help/index.html#usub
> > | OTHER HELP: http://evdl.org/help/
> > | OPTIONS: http://lists.sjsu.edu/mailman/listinfo/ev
