Hello
I connected the field to a 24 volt source, and I have
pack of 72 volts. But the car takes off, fine, but
then I'll stop, and it won't go up an incline.
Either I'm not exciting the field enough, or perhaps
the field shouldn't be turned off. I have connected it
to a relay on the microswitch on the PB-6...so maybe
that should on the fan relay. That turns on with the
key switch.
I'm also concerned about the curtis controller getting
too hot...of course, that won't be a problem next
month.
Mike
Fairbanks, Alaska
key switch.
month.
Mike
Fairbanks, Alaska
