1 - 2 of 2 Posts
Hello
I drove my Geo Metro in my yard ... a little bit.
I used 36 volts and a curtis 1204 (24-36v, 275 amp).
I didn't connect the fan to the G29 motor yet.
I was wondering if I made a mistake in going direct
drive. The car did not want to move unless it was on
level ground, when starting up.
When I add more volts and change the controller will
it make a difference?
My direct drive works like this. I have the motor
directly coupled to the transmission, so I still have
the clutch, minus the pedal.
Thanks in advance,
Michael Golub
Fairbanks
Shape Yahoo! in your own image. Join our Network Research Panel today! http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
Discussion Starter · #2 ·
Mike, I had the same problem with torque issues on
inclines using the G29 generator/motor. You'll want
to power the field winding separately with another
battery pack. Use the controller for strictly the
armature.
--- mike golub <[email protected]> wrote:
> Hello
> have
> Thanks in advance,
> Michael Golub
> Fairbanks
1 - 2 of 2 Posts
