[EVDL] Good source for ducting supplies
564 1
I ordered two of these blowers from Surples Center
http://www.surpluscenter.com/item.asp?UID=3D2007101211410562&item=3D16-1279=
&catname=3Delectric
I plan on using one for forcing air through my slightly undersized motor an=
d one to replace the stock fan of the heating system in my 1970 Datsun truc=
k. I am interested in plumbing both with something a little nicer then pap=
er towel rolls and duct tape, and I'm wondering if anyone has any good sour=
ces for the different size ducting and fittings I will be needing. I alrea=
dy know how to scrounge around at my local Home Depot, but if you know of a=
ny national specialty chains, online resources or local supply stores in th=
e Portland Or area that carry a good selection please share.
thanks
damon
Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop =
by today.
http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=3DTXT_TAGLM_Oc=
tWLtagline
1 - 2 of 2 Posts
Discussion Starter · #2 ·
Hello Damon,
Those are the correct size blowers you are getting. I have the same type. =
If you remote mount them and if you have the room, bolt the square output t=
o =
one side of the radiator support section or on to a panel that can be bolte=
d =
some where else.
I went to a auto parts store and bought a 6 inch carb air cleaner housings =
and fasten them to the round input section of the blower.
For a hose take off, I use standard 2 inch diameter pvc pipe fittings that =
I =
glue to a plastic flat plate that bolted to the square section of the fan. =
You then can run standard pvc air hose to your motor which you have to make =
another adapter to fit the hose.
Use the standard air hose for the air input and only use a thicker 1/4 pvc =
flex hose for exhausting battery exhaust fumes. These fumes will eat up th=
e =
thinner standard air hose in no time.
You can get these air hoses and heavy duty pvc air hoses up to 1/4 inch =
thick which is normally use for vacuum systems from the Home Depot or other =
industrial hard ward stores.
Roland
----- Original Message ----- =
To: "EV List" <[email protected]>
Sent: Friday, October 12, 2007 10:52 AM
Subject: [EVDL] Good source for ducting supplies
&catname=3Delectric
d =
one to replace the stock fan of the heating system in my 1970 Datsun truck. =
I am interested in plumbing both with something a little nicer then paper =
towel rolls and duct tape, and I'm wondering if anyone has any good sources =
for the different size ducting and fittings I will be needing. I already =
know how to scrounge around at my local Home Depot, but if you know of any =
national specialty chains, online resources or local supply stores in the =
thanks
damon
by =
today.
tWLtagline
http://lists.sjsu.edu/mailman/listinfo/ev =
1 - 2 of 2 Posts
