1 - 4 of 4 Posts
http://www.aero-model.com/Hacker-Brushless-A200-8.aspx
Is this BLDC or some sort of AC motor.
If AC can the Curtis 1234 control it?
Thanks
Michael
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101219/abbf7e75/attachment.html
Discussion Starter · #2 ·
I wastrying to find an efficiency curve for the Hacker Motor A200-8?
It's a small BLDC motor.
Anyone know what a good speed is to run it at?
I've called and emailed Hacker in Germany, but they are not helpful.
Also this is for a three wheel recombinant bicycle...
Thanks!
This link was found on RC Groups forum;
You might want to check cooling if used on a non-aero application
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/Hacker-Motor-A200-8-tp3439256p3439292.html
Google John Tetz. He has written several articles and belongs to a group
devoted to HPV and he uses this type of motor for an assist. If you can find
a contact from him, he should be able to give you the advice you are
seeking.
john
m gol <[email protected]> wrote:
> I was trying to find an efficiency curve for the Hacker Motor A200-8?
> Thanks!
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110411/34ff4227/attachment.html
1 - 4 of 4 Posts
