1 - 2 of 2 Posts
The heater core in my EV is shot, and I don't want to take apart the entire
dash to replace it. I'm wondering if there would be any issues with the
following two options:
1) The car originally had air conditioning, which I removed. Could I just
run hot water through the evaporator core?
2) I could buy a heater core to sit where the evaporator core used to be. =
The heater core would be vertical instead of flat. Is that okay for a core
meant to lie horizontally, or would I need to purchase a core specifically
meant to sit vertically?
Thanks.
Bill
myhosting.com - Premium Microsoft=AE Windows=AE and Linux web and applicati=
on
hosting - http://link.myhosting.com/myhosting
Discussion Starter · #2 ·
Dennis, ( It must be great to be related to the Greek Lord of Partying..(I
was only named after him.)
Regarding the EV business below #1 will work but the original H.V.A.C.
controls will behave "Differently" #2 will work in either position if you
include a circulating pump to maintain correct water flow. In either case
use an additive for aluminum radiator systems to help prevent internal
corrosion, unless the evaporator is copper.
Regards,
*Dennis L. Miles*
On Mon, Jan 24, 2011 at 7:57 PM, [email protected] <[email protected]>wro=
te:
> The heater core in my EV is shot, and I don't want to take apart the enti=
re
> 1) The car originally had air conditioning, which I removed. Could I ju=
st
> The heater core would be vertical instead of flat. Is that okay for a co=
re
> Thanks.
> Bill
> myhosting.com - Premium Microsoft=AE Windows=AE and Linux web and applica=
tion
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110124/672324b1=
/attachment.html =
1 - 2 of 2 Posts
