--- mike golub <[email protected]> wrote:
> HELLO
> I'm trying to duplicate what Michael did here:
http://www.texomaev.com-a.googlepages.com/mitsubishieclipseconversion
> Using the G-29 Aircraft Generator, and no
> flywheel...a
> direct connection to the transmission.
> I have a 1204 upgraded controller from logi
> 48-72volts, and I ran 48volts to the armature
> through
> the controller, and separate 24volts directly to the
> field.
> I used 8 awg wire for the 24 volt pack, and used a
> RY115 relay, which I thought was 30 amp, but it
> blew,
> so I removed a relay and connected through a 30 amp
> fuse.
> I then started the car, and I really did see that
> much
> difference.
> I guess all have to try a 72 volt pack, but I never
> found those improved coil springs for the geo
> metro...so I really didn't want to add another 200
> lbs
> in the rear.
> thanks in advance,
> Michael Golub
--- Michael Barkley <[email protected]> wrote:
> Mike, I purchased from JCWhitney a set of helper
> springs that bolt to the rear axle of a front wheel
> drive vehicle. They have them rated from 1000lbs to
> 2000lbs. I purchased the 2000lbs version and so far
> so good. I've got 13 golf cart batteries in the
> back
> of the Eclipse.
> If you aren't getting enough torque with the 24volt
> field pack, you might try 36vdc. I seem to have
> plenty of torque at 24vdc, but am running a 78vdc
> pack
> for the armature.
> > HELLO
> > flywheel...a
> > through
> the
> > field.
> > blew,
> amp
> > fuse.
> > much
> > difference.
> never
> > lbs
> > in the rear.
> > thanks in advance,
> > Michael Golub
> Here's a link to the coil helper springs at
> JCWhitney:
http://www.jcwhitney.com/wcsstore/jcwhitney/images/imagecache/G_15887G_CL_1.jpg
> Hopefully the link will work.
> wheel
> to
> far
> > back
> > of the Eclipse.
> 24volt
> > pack
> > for the armature.
> > > HELLO
> > > flywheel...a
> > > through
> > the
> > > field.
> a
> > > blew,
> > amp
> > > fuse.
> that
> > > much
> > > difference.
> > never
> 200
> > > lbs
> > > in the rear.
> > > thanks in advance,
> > > Michael Golub
> Do these replace the rear springs I have?
> Or is these an additional set?
http://www.jcwhitney.com/autoparts/Product/Pr-p_Product.CATENTRY_ID:2005887/c-10101/Nty-1/p-2005887/Ntx-mode+matchallpartial/N-10101/tf-Browse/s-10101/Ntk-AllTextSearchGroup?Ntt=helper+springs
> > JCWhitney:
> > wheel
> 1000lbs
> > to
> > far
> > > back
> > > of the Eclipse.
> > 24volt
> 78vdc
> > > pack
> > > for the armature.
> > > > HELLO
> > > > flywheel...a
> > > > through
> to
> > > the
> > > > field.
> used
> > a
> it
> > > > blew,
> 30
> > > amp
> > > > fuse.
> > that
> > > > much
> > > > difference.
> > > never
> > 200
> > > > lbs
> > > > in the rear.
> > > > thanks in advance,
> > > > Michael Golub
> They don't replace the original springs, just add
> them
> to the axle just beind the others, as close to the
> wheel you can. I believe a gentleman did post a
> website earlier in the list of a company that sells
> replacement coil springs to your weight
> specification.
> I believe these addon springs I used are less
> expensive though.
> I'm working on a tight no money budget with my
> project, so I've had to keep cost to a minimum.
> Still
> hoping someday, I'll walk outside, and find that a
> 1K
> zilla happened to be left on my doorstep to be
> adopted
> by my EV....... LOL
> > > JCWhitney:
> helper
> > > wheel
> > 1000lbs
> > > to
> so
> > > far
> the
> > > > back
> > > > of the Eclipse.
> > > 24volt
> have
> > 78vdc
> > > > pack
> > > > for the armature.
> > > > > HELLO
> here:
> > > > > flywheel...a
> armature
> > > > > through
> directly
> > to
> > > > the
> > > > > field.
> > used
> > > a
> > it
> > > > > blew,
> > 30
> > > > amp
> > > > > fuse.
> > > that
> > > > > much
> > > > > difference.
> I
> > > > never
> geo
> another
> > > 200
> > > > > lbs
> > > > > in the rear.
> > > > > thanks in advance,
> > > > > Michael Golub
> not sure with they'll fit in the Geo.
> > them
> sells
> > specification.
> > expensive though.
> > Still
> > 1K
> > adopted
> > by my EV....... LOL
> > > > JCWhitney:
> > helper
> front
> > > > wheel
> > > 1000lbs
> > > > to
> and
> > so
> > > > far
> > the
> > > > > back
> > > > > of the Eclipse.
> > > > 24volt
> > have
> > > 78vdc
> > > > > pack
> > > > > for the armature.
> > > > > > HELLO
> > here:
> > > > > > flywheel...a
> logi
> > armature
> > > > > > through
> > directly
> > > to
> > > > > the
> > > > > > field.
> and
> > > used
> > > > a
> but
> > > it
> > > > > > blew,
> a
> > > 30
> > > > > amp
> > > > > > fuse.
> see
> > > > that
> > > > > > much
> > > > > > difference.
> but
> > I
> > > > > never
> > geo
> > another
> > > > 200
> > > > > > lbs
> > > > > > in the rear.
> > > > > > thanks in advance,
> > > > > > Michael Golub
Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games.
http://sims.yahoo.com/
--- Bruce Weisenberger <[email protected]> wrote:
> DO NOT USED HELPER SPRINGS.
> A friend of mind used them to fix bad springs which
> where just worn out to get by on the Cheap. He was
> driving down the freeway and hit a rough spot and
> the
> helper springs Shot out side-ways and blew out both
> rear tires. Car was not a pretty site after wards.
> There has been a several discussion of this that you
> need to order custom wound springs from a specialty
> shop. I discovered going to a suspension shop for
> hot
> rods that they will measure your car up for custom
> springs and get them ordered up for you. a 4x4
> custom
> shop might be able to help you as well.
> add
> > > them
> the
> > sells
> > > specification.
> > > expensive though.
> > > Still
> a
> > > 1K
> > > adopted
> > > by my EV....... LOL
> > > > > JCWhitney:
> > > helper
> > front
> > > > > wheel
> > > > 1000lbs
> > > > > to
> > and
> > > so
> > > > > far
> in
> > > the
> > > > > > back
> > > > > > of the Eclipse.
> the
> > > > > 24volt
> to
> > > have
> a
> > > > 78vdc
> > > > > > pack
> > > > > > for the armature.
> > > > > > > HELLO
> > > here:
> no
> > > > > > > flywheel...a
> > logi
> > > armature
> > > > > > > through
> > > directly
> > > > to
> > > > > > the
> > > > > > > field.
> > and
> > > > used
> > > > > a
> > but
> > > > it
> > > > > > > blew,
> through
> > a
> > > > 30
> > > > > > amp
> > > > > > > fuse.
> > see
> > > > > that
> > > > > > > much
> > > > > > > difference.
> > but
> > > I
> > > > > > never
> the
> > > geo
> > > another
> > > > > 200
> > > > > > > lbs
> > > > > > > in the rear.
> > > > > > > thanks in advance,
> > > > > > > Michael Golub
=== message truncated ===
> I bet that was an experience, that you'd not want to
> do again for sure (was it an EV?). Thanks for that
> heads up, I'll go back and install rubber bumpers on
> the top portion of the car, where the springs sit,
> so
> the springs are restricted from side to side
> movement.
> which
> > the
> both
> you
> specialty
> > hot
> > custom
> > add
> > > > them
> > the
> a
> > > sells
> > > > specification.
> > > > expensive though.
> minimum.
> > > > Still
> that
> > a
> > > > 1K
> > > > adopted
> > > > by my EV....... LOL
> at
> > > > > > JCWhitney:
> of
> > > > helper
> > > front
> > > > > > wheel
> from
> > > > > 1000lbs
> > > > > > to
> version
> > > and
> > > > so
> > > > > > far
> batteries
> > in
> > > > the
> > > > > > > back
> > > > > > > of the Eclipse.
> > the
> > > > > > 24volt
> > to
> > > > have
> running
> > a
> > > > > 78vdc
> > > > > > > pack
> > > > > > > for the armature.
> wrote:
> > > > > > > > HELLO
> did
> > > > here:
> > no
> > > > > > > > flywheel...a
> > > logi
> > > > armature
> > > > > > > > through
> > > > directly
> > > > > to
> > > > > > > the
> > > > > > > > field.
> pack,
> > > and
> > > > > used
> > > > > > a
> amp,
> > > but
> > > > > it
> > > > > > > > blew,
> > through
> > > a
> > > > > 30
> > > > > > > amp
> > > > > > > > fuse.
> did
> > > see
> > > > > > that
> > > > > > > > much
> > > > > > > > difference.
> pack,
> > > but
> Well, it works
> The problem is that these free old UPS batteries are
> weak. I drove 6 miles.
> I'm a little concerned about downshifting. It didn't
> seem it wanted to do it.
> What do you do when slowing down?
> thanks
> to
> that
> on
> > so
> > movement.
> > which
> was
> and
> > > the
> > both
> wards.
> > you
> > specialty
> for
> > > hot
> custom
> > > custom
> just
> > > add
> > > > > them
> to
> > > the
> post
> > a
> that
> > > > sells
> > > > > specification.
> less
> > > > > expensive though.
> my
> > minimum.
> > > > > Still
> > that
> > > a
> > > > > 1K
> be
> > > > > adopted
> > > > > by my EV....... LOL
> > at
> > > > > > > JCWhitney:
> > of
> > > > > helper
> a
> > > > front
> > > > > > > wheel
> > from
> > > > > > 1000lbs
> > > > > > > to
> > version
> > > > and
> > > > > so
> > > > > > > far
> > batteries
> > > in
> > > > > the
> > > > > > > > back
> > > > > > > > of the Eclipse.
> with
> > > the
> > > > > > > 24volt
> seem
> > > to
> > > > > have
> > running
> > > a
> > > > > > 78vdc
> > > > > > > > pack
> > > > > > > > for the armature.
> > wrote:
> > > > > > > > > HELLO
> > did
> > > > > here:
> and
> > > no
> > > > > > > > > flywheel...a
> transmission.
> from
Michael Barkley wrote:
> I haven't figured out anyway to really downshift with
> the direct drive manual transmission either. I just
> take it out of gear, and coast as much as possible,
> and apply brakes gingerly.
To downshift my clutchless EVs, I'd take my foot off the accelerator so
it's coasting, shift into neutral and then into the lower gear. The
transmission's synchronizers pulled the motor speed down to match. If
there was no need to hurry, a shift took a couple seconds. If I wanted
to do it more quickly, I pushed harder on the gearshift lever so the
synchronizers pulled the speeds together faster.
This works well with some transmissions, poorly with others.
Forget the perfect offering
> with
> just
> possible,
> the accelerator so
> lower gear. The
> down to match. If
> others.
>> with
>> just
>> possible,
>> the accelerator so
>> lower gear. The
>> down to match. If
>> others.
> HELLO
> flywheel...a
> through
> field.
> blew,
> fuse.
The shunt field should be a lot less than 30 amps.
Take the resistance and let me know.
> much
> difference.
Did or did not? What is your problem? Sorry if I
missed that in a previous post. What is it doing and
what is it not doing?
> lbs
> in the rear.
The higher pack voltage will help at higher speeds.
If you're working at lower speeds, like acceleration
from a stop, you should be in current limit and higher
pack voltage on the armature shouldn't play a role.
> thanks in advance,
> Michael Golub
Give me some more details and I might offer some help.
Jeff M
Luggage? GPS? Comic books?
Check out fitting gifts for grads at Yahoo! Search
http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz
--- Jeff Major <[email protected]> wrote:
> Hey Mike,
> Michael had some problems with low starting torque.
> I
> was able to give him help. I might be able to help
> you out also, but need some more info. See inserted
> comments.......
> > HELLO
> > flywheel...a
> > through
> the
> > field.
> > blew,
> amp
> > fuse.
> > much
> > difference.
> and
> never
> > lbs
> > in the rear.
> higher
> > thanks in advance,
> > Michael Golub
> help.
> Jeff M
