I have an old surplus generator that I would like to use for a light EV. I have listed
the info from the tag below. Do you know what would be the max voltage and amperage
I could use with this? Also would it have enough starting torque to run direct? What
would be a safe rpm? It has 2 - 3/8 terminals and 2 – 3/16 terminals. I can send photo’s
if needed. It is supposed to be 24 volt and 200 amp output. It is 6" in diameter and 12"
long including air intake flange.
Thanks
Rick
Jack & Heinzt Inc.
Bedford, Oh.
Type R-1
Serial 8312
24 volt
AM G162>
Thanks
Rick
Jack & Heinzt Inc.
Bedford, Oh.
Type R-1
Serial 8312
24 volt
AM G162>
