[email protected]> wrote:
> Regulation. If you directly tie the batteries to the panels you could
> overcharge them. There has to be some kind of governer in the system to
> keep the panels from ruining the batteries.
> -----Original Message-----
> From:
[email protected] [mailto:
[email protected]] On
> Behalf Of keith vansickle
> Sent: Wednesday, August 22, 2007 10:47
> To:
[email protected]; Electric Vehicle Discussion List
> Subject: Re: [EVDL] input to battery chargers
> why go to all the work and expense and electronic losses of adding an
> inverter/charger loop when you can go directly from the solar panels to
> the batteries??
[email protected]" <
> > I am getting to the next design phase of my car. I am changing the
> > voltage from 120V of SLA batteries to 96V of flooded. The SLA are
> > still good, but I need more range than what they give. So I have a
> > thought to buy some solar panels to keep the SLA batteries charged,
> > and then run the battery charger off an inverter to charge my car.
> > This way, I hope to be able to reduce the electric bill slightly.
> > Does this sound feasible? I don't think the solar panels, which will
> > be mounted on my house, will completely supply enough power, but some.
> > So if this idea works, would I need to get a pure sine inverter to run
> > the charger? Or is a modified sine inverter sufficient? The modified
> > are much less expensive, so that would be nice. But I don't want to
> > destroy the charger. Any thoughts?
> > Thanks,
> > Brian
> > ---- Msg sent via @=WebMail -
> > http://webmail.usu.edu/
> > _______________________________________________
> > For subscription options, see
> > http://lists.sjsu.edu/mailman/listinfo/ev
> ________________________________________________________________________
> ____________Ready for the edge of your seat?
> Check out tonight's top picks on Yahoo! TV.
> http://tv.yahoo.com/
