[EVDL] Introduction - New EV List Member
945 Views 6 Replies 1 Participant Last post by  EVDL List
Hi all. I wanted to take a moment and introduce myself. My name is
Jeff; I'm an IT guy for a rehab hospital in Allentown, PA. I grew up
learning cars, computers, and electronics from my dad. Now, I'm a dad
of 3 myself and trying to save money and have fun at the same time.
I'm a long-time member at EcoModder and at CleanMPG, which has kept my
interest in hybrids and EVs growing.
Last fall I was talking to some friends and one of them mentioned that
they wanted to build an EV. Shortly thereafter, we had to replace some
of the batteries in our UPS. So I claimed the old ones. That, coupled
with friends interested in EVs, plus watching the development of the
Open Revolt PWM controller on EcoModder made me think we could really
do this!
So now, we're doing it. I have all sorts of stuff, and MANY things to
learn or re-learn. I've got a blog up to document the process - it can
be found at http://myelectriclife.wordpress.com
Thanks in advance for whatever you folks provide!
1 - 7 of 7 Posts
Jeff
Welcome to the fray. Glad to see another Least Coaster join the group.
I usually tow my EV through Allentown every year on my way to Power of
DC in Hagerstown.
The only bit of advice I'll offer up is that those UPS batteries are
may be good to get you going but probably won't last long term. IIRC
they just aren't designed for EV duty. But they may work to get your
EV up and running. Just plan for the pack voltage you want to run and
make your battery locations flexible. You can play around with
different voltage levels and see how the car performs before upgrading
your pack. I don't know how they will handle higher current levels and
frequent charge/discharge cycles.
I haven't been to the blog yet, but what are your goals for the car?
Daily driver, commuter, family wagon, racer? These decisions will have
a big impact on the components you use. Do you have a car picked out
yet?
Dave Cover, just up the road a way in Connecticut
> do this!
http://www.evalbum.com/2149
Batteries are small, and basically are going to be a 'test pack.' I've
got EIGHT sets of 96V, 7.2A (yep, they're tiny!) batteries. Each of
those 8 sets is made of 8 batteries - so I have 64 batteries at 12V,
7.2A each. I have a 2 HP permanent magnet DC motor from a treadmill,
as well at the complete electronics from a motorized
wheelchair/scooter. One of the other guys of our group has a go-kart
without a motor, so our plan was to start there.
The scooter electronics are fully functional:
Throttle assembly
Curtis 1208 PWM controller (36V max, 50A cont., 75A peak)
24V charger
Our plan is to get the go-kart moving (even if slowly) with a portion
of the batteries and the scooter controller. Once we have mobility,
the plan is to start building on of the open-source 144V 500A
controllers (or a variant thereof) from Paul Holmes on EcoModder.
After it's assembled, swap it in and use the go-kart for testing. Iron
out all the bugs, and then move the controller to a full car with a
new/different battery pack.
After talking to my uncles, one of them volunteered a VW Jetta that he
has sitting for the conversion. I don't know more details because I
was ecstatic to be donated a car for free that I just said thanks! I
plan to get details on year/etc from him this week.
Working in a rehab facility gives me pretty good access to ALL KINDS
of batteries - the UPS ones I have now, as well as all sorts of
wheelchair/scooter batteries. When the time comes for a *real* pack,
I'll probably go back to that department and see what I can scrounge
up.
I basically want the car to be a "local driver." Not looking for more
than 45 MPH max, 30-60 mile range. It'll be used to run around town
here for 3-10 mile jaunts, and to show off to friends and family. Not
looking for ultra max range or racing configuration; just looking (for
the moment) to be able to say "it works!" with the stuff I have on
hand.
dave cover <[email protected]> wrote:
> Jeff
> DC in Hagerstown.
> yet?
>> do this!
Excellent plan! You will learn much by starting small. I ran my motorcycle for a couple of years off of some surplus UPS batteries. They were larger than the small ones you are starting out with, 50lbs each (I still have a bunch of the small ones laying around as well). The UPS batteries were not ideal, but I got them for free and they handled the 100 - 300 amp loads fairly well with a reasonable lifespan, so you may just find something laying around that will get you on the road.
damon
> From: [email protected]
> Date: Tue, 1 Feb 2011 13:01:48 -0500
> To: [email protected]
> Subject: Re: [EVDL] Introduction - New EV List Member
> Throttle assembly
> 24V charger
> up.
> hand.
> > Jeff
> > DC in Hagerstown.
> > yet?
> >> do this!
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110201/e0ccfed7/attachment.html
On 1 Feb 2011 at 13:01, Jeff Haskell wrote:
> I have 64 batteries at 12V, 7.2A each.
I take it you mean 7.2 amp HOUR (AH) batteries.
But the amp-hour capacity is significant anyway.
Some AGM types (not all) can deliver 5-10 times their amp-hours, expressed
in amps (usually written as 5-10C), for brief periods. Of course if you ask
for those kinds of currents for very long or very often, they're going to
drain fast!
Other AGMs, and all gel batteries, can't produce more than 2C or even 1C
because of their higher internal resistance. Allowing for motor efficiency,
with a 96v string, that's only about 0.7 to 1.4 horsepower. That kind of
power is apt to make for a fairly dull ride, even with a light vehicle.
You could connect more than one string in parallel to increase the available
power and energy storage (more zoom for longer).
Just make sure that the strings are roughly the same voltage, so one doesn't
discharge the other. It wouldn't be uncommon for some of these used
batteries to have weak cells. I'd recommend carrying out load and capacity
tests on those batteries so you can weed out the stinkers.
> I have a 2 HP permanent magnet DC motor from a treadmill ...
> open-source 144V 500A controller ... Not looking for more than 45 MPH
This is a fairly realistic top speed goal for a homebrew vehicle, but I
don't think you'll get there with a treadmill motor! You'll need something
much more substantial. If you're into scrounging, you might try to find a
used pump motor from a forklift. Other scroungers here may have more
suggestions.
To achieve your range goals, you'll need to have 1/3 to 1/2 of the vehicle's
total weight in batteries.
Sounds like a fun project!
EVDL Administrator
Note: mail sent to "evpost" and "etpost" addresses will not
V2hvb3BzIC0gdHlwaW5nIHRvbyBmYXN0IGFuZCBsb3N0IHRoZSAiaCIgLSB5ZXMsIDcuMkFoIGVh
Y2guIFRoZXkgd2VyZQpzZXQgdXAgaW4gc2VyaWVzIG9mIDggdG8gZGVsaXZlciA5NlYgYXQgNy4y
QWguIEkgaGF2ZSA4IG9mIHRoZXNlCjk2Vi83LjJBaCAnY2FydHJpZGdlcycgKGZvciBsYWNrIG9m
IGEgYmV0dGVyIHRlcm0pLiBXaXRoIDY0IGNlbGxzLCBJCmNhbiBhZmZvcmQgdG8gbG9zZSBzb21l
LgoKVG8gY2xlYXIgdXAgY29uZnVzaW9uOgoKVGhlICdzbWFsbCcgYmF0dGVyaWVzIGFyZW4ndCBn
b2luZyB0byBnbyBpbnRvIHRoZSAnZnVsbCBzaXplJyBFViBmb3IKcm9hZCB1c2UuIFRoZXkncmUg
Z29pbmcgdG8gYmUgZm9yIHVzZSBhcyBhIGJlbmNoIHRlc3QgcGFjayBhcyB3ZWxsIGFzCmZvciBh
IHBhY2sgb24gdGhlIGdvLWthcnQuCgpDaGFpbiBvZiBFdmVudHMvUGxhbiBvZiBBdHRhY2s6Ci1H
ZXQgZ28ta2FydCBzZXQgdXAgZm9yIEVWIGRyaXZlLiBNb3VudCAySFAgbW90b3IsIG1ha2UgYmF0
dGVyeSByYWNrLApmaW5kIHByb3BlciBnZWFyIHJhdGlvIHRvIGRyaXZlIGF4bGUgd2l0aCwgc3By
b2NrZXQsIGV0Yy4KLVVzZSA1MEEgY29udHJvbGxlciBhbmQgVVBTIGJhdHRlcmllcyB0byBkcml2
ZSBhcm91bmQgd2l0aC4KLUJ1aWxkIDUwMEEgKG9yIG1vcmUpIE9wZW4gUmV2b2x0ICdDb3VnYXIn
IGNvbnRyb2xsZXIgdGhhdCBjYW4gdXNlCjEyLTE0NFYgbm9taW5hbCB2b2x0YWdlIGJhdHRlcnkg
cGFjawotVGVzdCBuZXcgJ2NvbnRyb2xsZXIgb24gZ28ta2FydCAocHJvZ3JhbW1pbmcsIHNvbGRl
cmluZywgZXRjKQotR2V0IGRvbm9yIGNhciBmcm9tIHVuY2xlLCBiZWdpbiBzdHJpcHBpbmcgZm9y
IEVWIGNvbnZlcnNpb24KLVdoaWxlIHN0cmlwcGluZyBjYXIsIGh1bnQgZm9yIEJJRyBtb3RvciBh
bmQgZGlmZmVyZW50IGJhdHRlcmllcy4KCkkgYmVsaWV2ZSB0aGF0IHNob3VsZCBjbGVhciB1cCBh
bnkgY29uZnVzaW9uLiBJIGhvcGU/IDopCgpJIGhhdmUgYSBsZWFkIG9uIGFuIEVaLUdPIGdvbGYg
Y2FydCBtb3RvciBmb3IgJDUwLiBJIGRvbid0IGtub3cgdGhlCnNwZWNzIG9uIGl0LCBidXQgZm9y
ICQ1MCwgSSBmaWd1cmVkIEknZCBlbWFpbCB0aGUgc2VsbGVyIGFuZCBhc2suCgoKT24gVHVlLCBG
ZWIgMSwgMjAxMSBhdCAxNToyMiwgRVZETCBBZG1pbmlzdHJhdG9yIDxldnBvc3RAZHJtbS5uZXQ+
IHdyb3RlOgo+IE9uIDEgRmViIDIwMTEgYXQgMTM6MDEsIEplZmYgSGFza2VsbCB3cm90ZToKPgo+
PiBJIGhhdmUgNjQgYmF0dGVyaWVzIGF0IDEyViwgNy4yQSBlYWNoLgo+Cj4gSSB0YWtlIGl0IHlv
dSBtZWFuIDcuMiBhbXAgSE9VUiAoQUgpIGJhdHRlcmllcy4KPgo+IEJ1dCB0aGUgYW1wLWhvdXIg
Y2FwYWNpdHkgaXMgc2lnbmlmaWNhbnQgYW55d2F5Lgo+Cj4gU29tZSBBR00gdHlwZXMgKG5vdCBh
bGwpIGNhbiBkZWxpdmVyIDUtMTAgdGltZXMgdGhlaXIgYW1wLWhvdXJzLCBleHByZXNzZWQKPiBp
biBhbXBzICh1c3VhbGx5IHdyaXR0ZW4gYXMgNS0xMEMpLCBmb3IgYnJpZWYgcGVyaW9kcy4gwqBP
ZiBjb3Vyc2UgaWYgeW91IGFzawo+IGZvciB0aG9zZSBraW5kcyBvZiBjdXJyZW50cyBmb3IgdmVy
eSBsb25nIG9yIHZlcnkgb2Z0ZW4sIHRoZXkncmUgZ29pbmcgdG8KPiBkcmFpbiBmYXN0IQo+Cj4g
T3RoZXIgQUdNcywgYW5kIGFsbCBnZWwgYmF0dGVyaWVzLCBjYW4ndCBwcm9kdWNlIG1vcmUgdGhh
biAyQyBvciBldmVuIDFDCj4gYmVjYXVzZSBvZiB0aGVpciBoaWdoZXIgaW50ZXJuYWwgcmVzaXN0
YW5jZS4gwqBBbGxvd2luZyBmb3IgbW90b3IgZWZmaWNpZW5jeSwKPiB3aXRoIGEgOTZ2IHN0cmlu
ZywgdGhhdCdzIG9ubHkgYWJvdXQgMC43IHRvIDEuNCBob3JzZXBvd2VyLiDCoFRoYXQga2luZCBv
Zgo+IHBvd2VyIGlzIGFwdCB0byBtYWtlIGZvciBhIGZhaXJseSBkdWxsIHJpZGUsIGV2ZW4gd2l0
aCBhIGxpZ2h0IHZlaGljbGUuCj4KPiBZb3UgY291bGQgY29ubmVjdCBtb3JlIHRoYW4gb25lIHN0
cmluZyBpbiBwYXJhbGxlbCB0byBpbmNyZWFzZSB0aGUgYXZhaWxhYmxlCj4gcG93ZXIgYW5kIGVu
ZXJneSBzdG9yYWdlIChtb3JlIHpvb20gZm9yIGxvbmdlcikuCj4KPiBKdXN0IG1ha2Ugc3VyZSB0
aGF0IHRoZSBzdHJpbmdzIGFyZSByb3VnaGx5IHRoZSBzYW1lIHZvbHRhZ2UsIHNvIG9uZSBkb2Vz
bid0Cj4gZGlzY2hhcmdlIHRoZSBvdGhlci4gwqBJdCB3b3VsZG4ndCBiZSB1bmNvbW1vbiBmb3Ig
c29tZSBvZiB0aGVzZSB1c2VkCj4gYmF0dGVyaWVzIHRvIGhhdmUgd2VhayBjZWxscy4gwqBJJ2Qg
cmVjb21tZW5kIGNhcnJ5aW5nIG91dCBsb2FkIGFuZCBjYXBhY2l0eQo+IHRlc3RzIG9uIHRob3Nl
IGJhdHRlcmllcyBzbyB5b3UgY2FuIHdlZWQgb3V0IHRoZSBzdGlua2Vycy4KPgo+PiBJIGhhdmUg
YSAyIEhQIHBlcm1hbmVudCBtYWduZXQgREMgbW90b3IgZnJvbSBhIHRyZWFkbWlsbCAuLi4KPj4g
b3Blbi1zb3VyY2UgMTQ0ViA1MDBBIGNvbnRyb2xsZXIgLi4uIE5vdCBsb29raW5nIGZvciBtb3Jl
IHRoYW4gNDUgTVBICj4+IG1heCwgMzAtNjAgbWlsZSByYW5nZS4KPgo+IFRoaXMgaXMgYSBmYWly
bHkgcmVhbGlzdGljIHRvcCBzcGVlZCBnb2FsIGZvciBhIGhvbWVicmV3IHZlaGljbGUsIGJ1dCBJ
Cj4gZG9uJ3QgdGhpbmsgeW91J2xsIGdldCB0aGVyZSB3aXRoIGEgdHJlYWRtaWxsIG1vdG9yISDC
oFlvdSdsbCBuZWVkIHNvbWV0aGluZwo+IG11Y2ggbW9yZSBzdWJzdGFudGlhbC4gwqBJZiB5b3Un
cmUgaW50byBzY3JvdW5naW5nLCB5b3UgbWlnaHQgdHJ5IHRvIGZpbmQgYQo+IHVzZWQgcHVtcCBt
b3RvciBmcm9tIGEgZm9ya2xpZnQuIMKgT3RoZXIgc2Nyb3VuZ2VycyBoZXJlIG1heSBoYXZlIG1v
cmUKPiBzdWdnZXN0aW9ucy4KPgo+IFRvIGFjaGlldmUgeW91ciByYW5nZSBnb2FscywgeW91J2xs
IG5lZWQgdG8gaGF2ZSAxLzMgdG8gMS8yIG9mIHRoZSB2ZWhpY2xlJ3MKPiB0b3RhbCB3ZWlnaHQg
aW4gYmF0dGVyaWVzLgo+Cj4gU291bmRzIGxpa2UgYSBmdW4gcHJvamVjdCEKPgo+IERhdmlkIFJv
ZGVuIC0gQWtyb24sIE9oaW8sIFVTQQo+IEVWREwgQWRtaW5pc3RyYXRvcgo+Cj4gPSA9ID0gPSA9
ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9Cj4gRVZETCBJ
bmZvcm1hdGlvbjogaHR0cDovL3d3dy5ldmRsLm9yZy9oZWxwLwo+ID0gPSA9ID0gPSA9ID0gPSA9
ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPQo+IE5vdGU6IG1haWwgc2Vu
dCB0byAiZXZwb3N0IiBhbmQgImV0cG9zdCIgYWRkcmVzc2VzIHdpbGwgbm90Cj4gcmVhY2ggbWUu
IMKgVG8gc2VuZCBhIHByaXZhdGUgbWVzc2FnZSwgcGxlYXNlIG9idGFpbiBteQo+IGVtYWlsIGFk
ZHJlc3MgZnJvbSB0aGUgd2VicGFnZSBodHRwOi8vd3d3LmV2ZGwub3JnL2hlbHAvIC4KPiA9ID0g
PSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0gPSA9ID0KPgo+
Cj4gX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18KPiB8IFJF
UExZSU5HOiBhZGRyZXNzIHlvdXIgbWVzc2FnZSB0byBldkBsaXN0cy5zanN1LmVkdSBvbmx5Lgo+
IHwgTXVsdGlwbGUtYWRkcmVzcyBvciBDQ2VkIG1lc3NhZ2VzIG1heSBiZSByZWplY3RlZC4KPiB8
IFVOU1VCU0NSSUJFOiBodHRwOi8vd3d3LmV2ZGwub3JnL2hlbHAvaW5kZXguaHRtbCN1c3ViCj4g
fCBPVEhFUiBIRUxQOiBodHRwOi8vZXZkbC5vcmcvaGVscC8KPiB8IE9QVElPTlM6IGh0dHA6Ly9s
aXN0cy5zanN1LmVkdS9tYWlsbWFuL2xpc3RpbmZvL2V2Cj4KCl9fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fCnwgUkVQTFlJTkc6IGFkZHJlc3MgeW91ciBtZXNz
YWdlIHRvIGV2QGxpc3RzLnNqc3UuZWR1IG9ubHkuCnwgTXVsdGlwbGUtYWRkcmVzcyBvciBDQ2Vk
IG1lc3NhZ2VzIG1heSBiZSByZWplY3RlZC4KfCBVTlNVQlNDUklCRTogaHR0cDovL3d3dy5ldmRs
Lm9yZy9oZWxwL2luZGV4Lmh0bWwjdXN1Ygp8IE9USEVSIEhFTFA6IGh0dHA6Ly9ldmRsLm9yZy9o
ZWxwLwp8IE9QVElPTlM6IGh0dHA6Ly9saXN0cy5zanN1LmVkdS9tYWlsbWFuL2xpc3RpbmZvL2V2
Cg==
I have already posted what I recommend as a good approach to an EV
conversion. So as to save evdl bandwidth, all new members seeking to
do an EV conversion, please read my approach at
http://brucedp.150m.com/ev-conversion-approach.txt
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/Introduction-New-EV-List-Member-tp3251845p3260919.html
1 - 7 of 7 Posts
