1 - 2 of 2 Posts
I was looking at the hours it's rated at and how that compares to most relays:
http://www.nteinc.com/relay_web/pdf/R51.pdf
Discussion Starter · #2 ·
> most relays: http://www.nteinc.com/relay_web/pdf/R51.pdf
It's a typical automotive-grade relay. Very low contact voltage rating (14v), and only DC resistive current ratings. That's how they get such a high current rating out of such a small relay.
Note that automotive relays should not be used where you have a high voltage difference between the coil and contacts.
"Excellence does not require perfection." -- Henry James
Lee A. Hart, 814 8th Ave N, Sartell MN 56377, leeahart-at-earthlink.net
1 - 2 of 2 Posts
