1 - 2 of 2 Posts
What about using and IOTA DLS-48-15.
http://www.iotaengineering.com/dls4815.htm
Although it is an AC input SMPS, many of us use their products on DC and
110VAC is about 170V peak so running it on a 144V pack is perfect. (both
charge and discharge voltages are within operational range.) No-one
here has tested this particular module on dc yet I have the DLS-55
It may cut out if pack is low and sags to far, certainly we must de-rate
the output when that happens. So 15A unit is a good choice for 10A of need.
Discussion Starter · #2 ·
I have tested the 24V version on DC and it works fine.
(140Vdc).
Rod
> range.) No-one
> have the DLS-55
1 - 2 of 2 Posts
