My 1981 Jet Electrica battery disconnect failed, probably from wear
causing insufficient tension, and resulted in arcing and melting
of the brass screw (modified) that contacted a heavy copper bus.
I obtained the 2 1/2 inch by 3/8 16 threads per inch
brass screw from McMaster and ground the round head flat
and reassembled the unit.
As an emergency work-around when we lost power I bolted
the battery cable direct to the fuse, by-passing the
disconnect. This removes the manual disconnect and
leaves you somewhat unprotected. (9/16 inch wrench!)
The disconnect was made by DE-STA-CO and is probably one
of these:
http://www.destaco.com/products.asp?loc=USA&lang=ENG&products=Manual%20Clamps&Category_1=Vertical+Handle+Hold%2DDown+Clamps&Category_2=Standard
It has been modified with a small tab welded on for the
pull wire to the big red E under the dash.
CAUTION! A plastic ferrule insulates the pull wire
from the hold-down and if improperly oriented can lead to battery
voltage applied to the wire, and then ground.
John in Sylmar, CA
Who lost 5 minutes on the road, and 3 days awaiting the brass screw.
of these:
John in Sylmar, CA
