21 - 27 of 27 Posts
Discussion Starter · #21 ·
Re: [EVDL] kelly controllers
What controller? I will go have a look at the schematic for hooking it
up. I'd almost bet it is still good.
Pete
[email protected] wrote:
> what it did was red lights only like 4 flashing ..i used first time
> there
> diagram from web site for kdh controller .
> 2nd time used there high powered assembly unit pre wired but whats
> odd is
> b- is bolted to alluminium plate .. anyhow now all got is solid red
> light
> ,, kelly controllers is giving me hard time on refund or replacement
> .lonnie 626 398 0674 thx for reply
> [email protected]
>> Send me the schematics you are using to hook it up. I had the same
>> issue and I may be able to help you get around that. Mine is working.
>> I did have the red light for awhile while we tracked down the
>> issue. I
>> won't say until I am sure what I am thinking is the problem but I am
>> pretty sure I can help get around that.
>> Pete
>> On Jul 14, 2008, at 6:52 PM, acdcev wrote:
>>> hi anyone else had problems with kelly controllers and products ?/
>>> im having
>>> a bad nightmare with them . even with it on a wired assembly
>>> plate ,all got
>>> was red blinking lights , its rated up to 120 volts and says can
>>> handle 138
>>> volts ,, is it possible my 120 volt system the controller wont
>>> handle it
>>> ???/ the rest of this kelly problem is a long story ............ac
>>> dc ev
>>> lonnie
>>> View this message in context:
>>> http://www.nabble.com/kelly-controllers-tp18456649p18456649.html
>>> Sent from the Electric Vehicle Discussion List mailing list archive
>>> at Nabble.com.
>>> _______________________________________________
>>> For general EVDL support, see http://evdl.org/help/
>>> For subscription options, see http://lists.sjsu.edu/mailman/
>>> listinfo/
>>> ev
>> For subscription options, see http://lists.sjsu.edu/mailman/listinfo/ev
> ev
Discussion Starter · #22 ·
hi believe page 10 of manual . i have no reverse it was a KDH12600 , i
got 10 12 volt wired in series .. also in web site has the high powered
assembly unit i got .with a power box ... thx lonnie at first thought
it was my pedal switch wiring ,which kelly gave me one way , electric
vehicles usa a different way etc etc . all i know is i got now 1500.00
invested in controller assembly and still cant run my ev .getting very
discouraged ... thx 4 help lonnie
[email protected]
> Pete
>> there
>> odd is
>> light
>> [email protected]
>>> issue. I
>>> Pete
>>>> im having
>>>> plate ,all got
>>>> handle 138
>>>> handle it
>>>> dc ev
>>>> lonnie
>>>> at Nabble.com.
>>>> listinfo/
>>>> ev
>> ev
Discussion Starter · #23 ·
[EVDL] Kelly Controllers
Hey folks,
I'm in a dilemma at the moment. I'm waiting on a Logisystems controller but
have been told I can get a Kelly controller right away. Itt would be a
144V, 650 amp unit. Anybody out there have any experience with this
controller brand (or this unit in particular)? I'm espcially interested in
hearing from anyone who actually is driving around an EV with one in it.
Comments both positive and negative welcome.
Thanks.
Peter Flipsen Jr
General EVDL support: http://evdl.org/help/
Usage guidelines: http://evdl.org/help/index.html#conv
Archives: http://evdl.org/archive/
Subscription options: http://lists.sjsu.edu/mailman/listinfo/ev
Discussion Starter · #24 ·
Re: [EVDL] Kelly Controllers
It's a long read, but I found this discussion very informative:
http://www.diyelectriccar.com/forums/showthread.php/kelly-controller-kdh12600-post-mortem-22300.html
Josh and Jen
> Hey folks,
> but
> in
> Thanks.
> Peter Flipsen Jr
Discussion Starter · #25 ·
Thanks for the input guys - to respond to a couple of messages at once:
1. I believe the controller is model KDH14651B.
2. The link is indeed to a long thread and one that I readily admit has
more math and engineering than I can follow (much of what I see on this list
is way over my head). But the bottom line seems to be to avoid them.
I think I'll just wait on the Logisystems controller.
- Peter F
Ian Hooper <[email protected]> wrote:
> I agree with Harry, in practice it seems you pretty much need twice
> the current rating compared with other brands e.g Curtis/CafeElectric,
> for equivalent performance. Me thinks they're a little generous with
> their specs!
> Also you'll most likely require additional cooling, e.g a fan-forced
> heatsink attached to the base of the unit. (Especially with the KDHA
> series.)
> FWIW my personal experience is with the earlier KDH14500 but a friend
> of mine has a KDHB14650 IIRC and says it's the same story.
> Ian Hooper
> "Never doubt that the work of a small group of thoughtful, committed
> citizens can change the world." - Margaret Mead
> http://www.zeva.com.au
> On 04/12/2008, at 12:51 PM, dale henderson wrote:
> > i'm assuming that link was for the KDHa12600? if so i my friend had
> > the same experince, hers bluw before she got it on the road.
> > i have a kdhB14650 the 144 volt 650 i've put about 100 miles on it
> > thus far, it seems fine, but it does suffer the same issue i've
> > heard others say: it only gets about half the rated power and less
> > if its hot.
> > so i would stay away from the kdhAs and if you get a kdhB get double
> > the amps, which is not hard there up to 1200 amps right now
> > harry
> > Albuquerque, NM
> > current bike: http://www.austinev.org/evalbum/1179
> > current non-bike: http://evalbum.com/1581
> > --- On Wed, 12/3/08, Josh Creel <[email protected]> wrote:
> >> From: Josh Creel <[email protected]>
> >> Subject: Re: [EVDL] Kelly Controllers
> >> To: "Electric Vehicle Discussion List" <[email protected]>
> >> Date: Wednesday, December 3, 2008, 11:22 PM
> >> informative:
> >> Josh and Jen
> >>> Hey folks,
> >>> but
> >>> in
> >> EV with one in it.
> >>> Thanks.
> >>> Peter Flipsen Jr
Discussion Starter · #26 ·
We should have a couple of Logisystems in stock in a few weeks (hopefully)
I'm going to call them and see If I can get one of them changed to 144/156V
1000amp. The others will be 120/144V 750 amp.
As far as the Kelly's go, After I read the whole thread, the
impression I got was to be careful with the A models, and a lot of
improvements have went into the B models. I think their customer support is
pretty good, going by what I read. I've tried to contact them, but
haven't heard anything from them yet.
Josh and Jen
www.jcsevparts.com
----- Original Message -----
> list
> - Peter F
Discussion Starter · #27 ·
Thanks.
- Peter
> is
> Josh and Jen
> www.jcsevparts.com
> > list
> > - Peter F
21 - 27 of 27 Posts
