Hi, For whatever reason, a fairly new 12v/22AH Universal battery has
crapped out. It shows full charge into the 13 volts, but upon using it
with the three other (same vintage, same specs, no problems) batteries
in a 48 volt string... It works for a short time then drops to
10-something volts. I can probably take it in under warranty but I am
wondering if there are any tricks to revive it to full capacity? P.S.
I use a 6amp smart charger and it is fine.
Jeff K. Burbank, CA
Jeff K. Burbank, CA
