[EVDL] Lee's Light bulb regulater
745 Views 4 Replies 1 Participant Last post by  EVDL List
I went to http://www.seattleeva.org/wiki/Zener-lamp_regulator
to see what exact value the zener diodes where and on the site it
showed two 5.1v zener . This seems very low for a 12v agm .
seems like I remember 6.8v but this also seems a bit low as two would
add up to 13.6v . I know the lights will drop some of the voltage .
Steve Clunn
Tomorrows Ride TODAY !
Visit our shop web page at: www.Greenshedconversions.com
1 - 5 of 5 Posts
Discussion Starter · #2 ·
Typical use for Lead-Acid is one 6.2 and one 6.8V, adding up
to 13V which may be slightly under the fresh-off-charger
voltage (my AGMs stayed at 13.25V for hours when left alone
after a fresh charge) but this will only remove a slight bit of
surface charge, the batteries will typically sit at anywhere
between 12 and 12.8V depending on SOC (empty - 99% full)
So the 13V drop allows a 2.5 or 3V bulb to regulate the full
batteries which try to go to 15+ Volts while the lower ones
are catching up.
It is important to have your charger throttle back, preferably
to less than 1 Amp at that point, so that the full batteries
are not hit too hard while the lower ones can catch up in the
course of hours if necessary.
With the batteries coming closer together during each charge
cycle, the time they spend equalizing should reduce over time
and after a while only the difference in self-discharge should
be visible in some balancers coming on later than others.
When you see all lights on you should terminate the charge,
it is just wasting energy.
Another very important thing is to use GOOD quality bulbs.
Cheap ones tend to fail early and now you have constructed
an UN-balancer!
There are people who say you should not use bulbs at all, only
resistors (and maybe a small LED with series resistor to give
an indication without affecting operation much) to make the
balancers robust.
The whole idea is to draw *no* current when the battery is
below its max resting voltage and to draw full current at the
max charging voltage.
Success,
Cor van de Water
Email: [email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: [email protected]
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of Steve Clunn
Sent: Sunday, September 05, 2010 9:55 AM
To: [email protected]
Subject: [EVDL] Lee's Light bulb regulater
to see what exact value the zener diodes where and on the site it showed
Steve Clunn
On 5 Sep 2010 at 0:25, Steve Clunn wrote:
> what exact value the zener diodes were ...
Here's the schematic with component values :
http://www.evdl.org/lib/mh/docs/battreg.pdf
EVDL Administrator
Note: mail sent to "evpost" an "etpost" addresses will not
Wow, I didn't realize in how many places there is info about Lee's Zener
regulators...
Here is another http://teva2.com/projects.htm
Rush Dougherty
www.TEVA2.com
Tucson AZ
----- Original Message -----
To: <[email protected]>
Sent: Saturday, September 04, 2010 9:25 PM
> Steve Clunn
With the interest in these regulators, I finally went back through the
archives and compiled most of what Lee had written into what I hope is a
fairly complete description of how they work, along with instructions on how
to build them.
Cor Van de Water sent along his suggestions on a slightly different circuit
using an LED and resistors in place of the lamps, so I included that
suggestion too, for those who might wish to try it.
I hope it helps someone.
http://www.evdl.org/pages/hartregs.html
I also compiled suggestions on recasting battery posts by Steve Clunn,
Roland Wiench, and Bob Rice. These are of course strictly for information,
entertainment, and education, since I don't want anyone to get hurt. ;-)
http://www.evdl.org/pages/battpost.html
EVDL Administrator
1 - 5 of 5 Posts
