[EVDL] li magnanesse battery
1297 Views 2 Replies 1 Participant Last post by  EVDL List
check out this source of batteries .
http://www.torqeedo.com<http://www.torqeedo.com/>
what do you guys think better source than dewalt ?
1 - 3 of 3 Posts
Seems kinda expensive for a higher voltage system:
Power 26-77 UI (User installation) LIMA high-performance battery
capacity: 1,994 Wh,
rated power: 25.9 V,
charge: 77 Ah,
weight: 40 lbs,
connection with other Torqeedo Power batteries limited to 2 batteries for
serial connection and to 4 batteries in total.
$ 3,599.00
Torqeedo Power 26-77 battery block General data
Capacity: 2.0 kWh
Charge: 77 Ah
Rated voltage: 25.9 V
Final charge voltage: 29.4 V
Weight: 40 lbs
Dimensions (length x width x height): 20 x 7 x 9 inches
Electrochemical base: Lithium manganese (LIMA)
High-current resistance
Maximum yield: 3.1 kW
Maximum power consumption: 120 A
----- Original Message -----
To: "ev" <[email protected]>
Sent: Saturday, October 20, 2007 6:52 PM
Subject: [EVDL] li magnanesse battery
1 - 3 of 3 Posts
