How large should a cooling blower be? Terms of CFM or watts would be
helpful. I would like to run the blower at pack voltage of 108 volts. I
do not have a DC to DC converter and would like to limit the draw on the
12 volt system. Would any of these blowers from Surplus Center Work?
https://www.surpluscenter.com/sort.asp?catname=electric&keyword=EBFA
How can you tell if they are universal AC / DC motors?
I am using a 9 inch 120 lbs compound wound motor. Brush temps now
reach 170f. Air could be blown in the brush end through the motor to
holes in the drive. Airflow would cover the brushes,coils and exit
behind the flywheel.
Thanks, Brad
Thanks, Brad
