Mark,
- Do you really need to be able to shunt 5A if your charger
immediately limits to 3 when you start balancing?
- What terminates charging? Is it the All OK signal? If so, are all
batts necessarily at the same SoC, since you use different balancing
currents at different OCV's? Or is the variation in current to adjust
for the series resistance of the battery?
- Like Steven said, try to make it such that a broken reg signals an
error. You could even use an active signal that toggles or something
instead of a simple logic level (Linear Tech makes a battery monitor
IC that does this).
- I like the backup OV comparator. It means you have no single point
of failure.
Great ideas! Keep us posted
-Ben
IC that does this).
of failure.
-Ben
