I have a EVI MCS 100-3 EVSE that I have retrofitted by replacing the Avcon with a Yazaki. What I have discovered however is that this particular unit was programmed to only allow one charge cycle per charge request. That is to say once a charge request is completed the unit will no longer provide a pilot signal until it is unplugged and plugged back in again. This behavior prevents the EVSE from working properly with my new Leaf.
According to Jason at ClipperCreek this programming was done to get around a bug that was in the original Honda EV Plus. The bug was that after the Honda EV Plus finished a charge cycle it would keep listening to the pilot if it was plugged in and would eventually kill the 12 volt battery as a result. So having the pilot shut down after one cycle prevented this.
I was told by the folks at ClipperCreek that there is currently no practical method to remove this single cycle programming from this unit and I should just consider buying a new unit or continue to work with this unit as is. I was also told that they no longer have the documents or programming equipment for this unit.
What information about the unit I could find on the web http://www.bowzerbird.com/eviweb/products2.html#mcs100
So I am looking for help in removing this single cycle feature. Any help or suggestions will be appreciated. Thanks!
Send and receive anonymous emails to your inbox with InboxAlias.
http://www.inboxalias.com
