Thanks for the suggestion but unfortunately that will not work in my case.
I had already thought about doing what you suggest and simulated it by
momentarily, like for a split second, disconnecting the pilot within
the EVSE while plugged into the Leaf. The result is that the Leaf
still goes through this "testing" cycle where it requests a momentary
charge. The Leaf does this cycle every time it is plugged in or in
this case when the pilot returns. Creating the circuit that you
mention would just end up having the EVSE and the Leaf in an infinite
loop.
In the end I guess what I am looking for is a replacement pilot
generator that I can use in this EVSE or a way to hack the EVSE in
such a way that removes the disabling of the pilot after a cycle. I
am fairly good with tools and electronics and I am willing to
disassemble this EVSE for further exploration since with its current
limitation it is not much good for using with the Leaf. I can get by
with just L1 charging with the Leaf for now but if I don't find a
solution for this EVSE soon I will probably purchase a different EVSE
and offer this one for sale.
loop.
<[email protected]> wrote:
> Original email sent from: [email protected]
> So, what you want is a small circuit that listens to the pilot,
> when the pilot completely disappears it will power up a relay
> where the relay has a normally closed contact in the feed to
> the charger, so the charger auto-resets itself as soon as
> the pilot signal disappears.
> This what you want?
> How experienced are you with designing and building some
> electronics?
> This would probably not be more than 2 transistors,
> a capacitor, three resistors, a diode and a relay.
> Regards,
> Cor van de Water
> Director HW & Systems Architecture Group
> Proxim Wireless Corporation http://www.proxim.com
> Email: [email protected] Private: http://www.cvandewater.com
> Skype: cor_van_de_water IM: [email protected]
> Tel: +1 408 383 7626 VoIP: +31 20 3987567 FWD# 25925
> Tel: +91 (040)23117400 x203 XoIP: +31877841130
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On
> Behalf Of [email protected]
> Sent: Tuesday, February 01, 2011 2:24 AM
> To: [email protected]
> Subject: [EVDL] Need help retrofitting EVI MCS 100-3 EVSE
> I have a EVI MCS 100-3 EVSE that I have retrofitted by replacing the
> Avcon with a Yazaki. What I have discovered however is that this
> particular unit was programmed to only allow one charge cycle per charge
> request. That is to say once a charge request is completed the unit
> will no longer provide a pilot signal until it is unplugged and plugged
> back in again. This behavior prevents the EVSE from working properly
> with my new Leaf.
> According to Jason at ClipperCreek this programming was done to get
> around a bug that was in the original Honda EV Plus. The bug was that
> after the Honda EV Plus finished a charge cycle it would keep listening
> to the pilot if it was plugged in and would eventually kill the 12 volt
> battery as a result. So having the pilot shut down after one cycle
> prevented this.
> I was told by the folks at ClipperCreek that there is currently no
> practical method to remove this single cycle programming from this unit
> and I should just consider buying a new unit or continue to work with
> this unit as is. I was also told that they no longer have the documents
> or programming equipment for this unit.
> What information about the unit I could find on the web
> http://www.bowzerbird.com/eviweb/products2.html#mcs100
> So I am looking for help in removing this single cycle feature. Any
> help or suggestions will be appreciated. Thanks!
> _________________________________________________________________
> Send and receive anonymous emails to your inbox with InboxAlias.
> http://www.inboxalias.com
> | REPLYING: address your message to [email protected] only.
