I bought my 1994 Saturn new, the only new car I've ever purchased. It has over
200,000 miles (an estimate, the odometer broke at 143,000)
I've often thought about converting it to electric, but it's just to crappy to
do so! It's a manual like all of my other cars, and it's amazing the shift
linkage has never broke. Thanks for the info guys, I may need it in the future,
electric or not (it currently is used as a 'winter car' in Ohio).
The winter car, summer car and neighborhood EV all in one shot
http://picasaweb.google.com/rodnhower/350Z#5337339587470618866
----- Original Message ----
[email protected]>
To:
[email protected]
Sent: Tue, October 5, 2010 9:51:31 PM
Subject: Re: [EVDL] One of those EV moments - shift cable breaks
eBay, where you can buy just about anything!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120587372654&viewitem=&sspagename=STRK%3AMEWNX%3AIT
Or search for user "saturnbushingman"
He has them CNC made, they're $20, but it's well cheaper than buying new cables.
And yes if you go to Saturn or any other parts supply all they have are the
cables. Mine seem ok otherwise so hopefully this will work. I'll let you know.
By your picture my failure looks identical to yours. Ironically the car showed
174999 miles at the time, it just couldn't make it to 175K!
And regarding the comment that it rains in AZ, yes amazingly it does. We had the
worst storm I can remember today with hail so bad it caused damage to cars,
luckily my EV was left at home parked in the garage. I guess the broken shifter
linkage probably saved the car. The sky light in my home now truly has a sky
view, it busted from quarter size hail.
Regards,
Ricky Suiter
Elite Power Solutions LLC
92 Saturn SC Conversion
> Message: 7
> Date: Tue, 05 Oct 2010 10:10:50 -0400
> From: "Barry Oppenheim" <
[email protected]>
> breaks
> To: "'Electric Vehicle Discussion List'" <
[email protected]>
> Message-ID: <
[email protected]>
> Content-Type: text/plain; charset=us-ascii
> -----Original Message-----
> From:
[email protected]
> [mailto:
[email protected]]
> On Behalf
> Of Bob Rice
> Sent: Tuesday, October 05, 2010 9:20 AM
> Rick,
> Where did you find the bushings? I ended up breaking
> the bushings when I
> originally converted my Saturn Vue. I searched high
> and low and could not
> find them for the life of me. The only way to get
> them was to buy the $200
> linkage cables that were attached to them! I ended up
> making by own:
> http://justanotherevconversion.blogspot.com/2008/11/just-035-vs-20000.html
> Barr
> New Hope, PA
> www.JustAnotherEVConversion.blogspot.com
> ----- Original Message -----
> From: "Ricky Suiter" <
[email protected]>
> To: "EV List" <
[email protected]>
> Sent: Tuesday, October 05, 2010 2:09 AM
> Subject: [EVDL] One of those EV moments - shift cable
> breaks
> > Had to share this before I go to bed tonight. I had
> one of those EV
> > moments today. I went to leave work today, my car
> parked inside the
> > warehouse. I backed normally, got out and locked up
> the doors, it was
> > starting to rain at this point, came back to the car,
> put it in gear and
> > realized the shift linkage had broken on me, the car
> was stuck in neutral.
> > This would normally be a tow it to a shop problem, but
> the EV doesn't
> > necessarily have this problem. I opened the hood,
> moved the shifter
> > linkages around and found some gear, got in and hit
> the pedal and it
> > wasn't reverse! Since I was moving I figured what the
> heck, lets see if I
> > can make it home. I figured out shortly I was locked
> in 4th, all well. I
> > drove 12 miles home in the rain in one gear, pulled in
> to my garage at
> > home and just had to laugh. Only in an EV!
> > Turns out the bushing on the shifter itself broke off,
> it's a common
> > problem on Saturns turns out. Luckily there is an
> aftermarket bushing I
> > ordered which avoids me having to replace the whole
> shifter linkage and
> > fixes the weak link.
> > Regards,
> > Ricky Suiter
[email protected] only.
