1 - 13 of 13 Posts
I just tried my brand new set of Optima Bluetops in my Sparrow. Put
about 3 miles on the bird.
Now, 1 of the Optimas is giving a just-audible hiss/crackle sound. Even
with the car completely turned off.
It's voltage seems ok.
It shouldn't make *any* sound. Perhaps you got one with a bad vent? I
would take it back.
Forget the perfect offering
Zeke Yewdall wrote:
> The D34 optimas come in both a blue and yellow version I think, and
> are the same except for terminals. The blue tops have the screw post
> and the regular automotive terminal, whereas the yellow top have the
> automotive terminal and the GM side terminals. Maybe...
The D34/78 yellowtops have the automotive posts and GM side terminals;
the D43 yellowtop has just the automotive posts.
Cheers,
Roger.
Discussion Starter · #7 ·
Yup, and the screw posts make connecting regs easy.
Discussion Starter · #9 ·
How do you unsubscribe from this list ? I havent been
able to do it right
--- patrick DonEgan <[email protected]> wrote:
> So, are you saying there is NO difference in
> chemistry betwixt them
> now?
> On 9/4/07, John G. Lussmyer <[email protected]>
> easy.
> Patrick Ira Donegan
> TigerBody Electric Vehicles
able to do it right
> now?
> easy.
> Patrick Ira Donegan
Discussion Starter · #11 ·
patrick DonEgan wrote:
> So, are you saying there is NO difference in chemistry betwixt them
> now?
Right, and as far as I know there never was.
Cheers,
Roger.
Discussion Starter · #13 ·
Bill Dube wrote:
> When Optima was not owned by JCI, there were two types of BlueTops.
> One was a YellowTop inside, and the other was a RedTop inside. Some
> boats just need starting batteries with maximum cranking amps. Other
> boats need deep cycle batteries with some compromise in cranking amps
> to allow repeated deep cycling.
This is still the situation, with the deep cycle/SLI nature of the
battery indicated by the colour of the battery case, as in the past.
Light grey case = deep cycle, regardless of the lid colour; dark grey
case = SLI, regardless of the lid colour.
Since only the deep cycle variety are of interest to non-drag racing
EVers, I made the assumption that Patrick was asking about the deep
cycle blue top vs the deep cycle yellow top.
Just browsing the technical specs on the Optima website will reveal that
the D34M blue top and D34 yellow top batteries have identical specs (CA,
CCA, RC, C/20), and that the "D" in the "D34" model designation
indicates a deep cycle model.
Cheers,
Roger.
1 - 13 of 13 Posts
