1 - 1 of 1 Posts
Do you mean 13V under charge at 12A? Is that one weak one warm? one
cylinder noticeably warmer than rest? drops to 8V-10V when remove power?
If answer is yes A cell is reversed! Set to 1amp max and charge for a
day until it's open circuit is above 12V then charge normally.
I did this to an orbital. similar construction.
1 - 1 of 1 Posts
