Lee Hart <
[email protected]> wrote:
> On 9/21/2010 11:18 AM, Roger Stockton wrote:
> > Another option is to use a reed relay; one almost has to search to find
> one rated to switch less than 200VDC @ 0.5A. They tend to be smaller and
> cheaper than the electromechanical alternatives (e.g. the Schrack relay
> above, PB1161-ND at Digikey, is $5.69ea, while the HE125-ND reed relay,
> rated to switch 300VDC and 0.5A and carry 1.2A, is $2.21).
> That should be a good choice for this application, since KSI draws very
> low current.
> Lee A. Hart | Ring the bells that still can ring
> 814 8th Ave N | Forget the perfect offering
> Sartell MN 56377 | There is a crack in everything
> leeahart earthlink.net | That's how the light gets in -- Leonard Cohen
> | REPLYING: address your message to
[email protected] only.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20100926/9fe581a0/attachment.html
