1 - 2 of 2 Posts
Since I'm switching to a resistive, as opposed to inductive throttle soon, =
I'd like to have a replacement PB-6 pot at the ready for when this one wear=
s out. I've followed some of the threads, but here are my issues:- I don=
't need the PB-6 housing, just the pot. Anyone know the Digi-Key part nu=
mber?- How many miles have people gotten on average with the potbox setup? =
(Just cuiriousThanks!
Thinking about converting a gen. 5 ('92-95) Honda Civic? My $23 "CivicWith=
ACord" DVD (57 mins.) shows ins and outs you'll encounter converting the se=
dan; the del Sol, or the hatchback. Each runs 144V/18 batteries. Primary f=
ocus on component/instrumentation/ battery placement and other consideratio=
ns. For more info, http://home.budget.net/~bbath/CivicWithACord.html
____ =
__/__|__\__ =
=3DD-------/ - - \ =
'O'-----'O'-'
Would you still drive your car if the tailpipe came out of the steering whe=
el?
OR Lic. "LCTRNS"
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101013/a581e7a8=
/attachment.html =
Discussion Starter · #2 ·
Jeff Major wrote:
> The PB6 pot is special because it has the internal element set up for
> an 80 degree (approx) twist of the shaft. Standard pots use like a
> 270 degree rotation. It may be possible to use a standard pot with a
> higher resistance for the limited throw in the PB6 if you are using a
> 2 wire system.
Yes, I've used a 25k pot this way. Many EV controllers are set up for a
0-5k (or 5k-0) throttle input, so it works fine.
Don't use a cheap unsealed pot like Curtis and the clones (gee, that
sounds like a band :)
GE used a MIL-spec RV4N "extended life" Allen Bradley type "J" sealed
pot in their EV1 controller potboxes. They seem to last forever; I've
never seen one go bad (except from extreme mechanical abuse). They used
a pair of gears in their potboxes so a 1/4-turn of the lever arm rotates
the pot a full 300 deg.
PS: I have a GE potbox that I opened up to check on its wiring. It
turned out to be optical! The sliding shaft moved a metal shutter plate.
Holes in this plate were sensed by opto-interrupters. There was just a
tiny bit of logic to convert the gray code produced by the interrupters
into binary, which selected a 1-2-4-8 series of resistors. for the 0-5k
output.
1 - 2 of 2 Posts
