Hello Dave,
Check your controller data to see how much ohms range you need with a
potentiometer. Normally these are from 0 to 5000 ohms. A Curtis pot box
only needs to turn 90 degrees for a reading of 0 to 5000 ohms. My
controller does not start turning the motor until the potentiometer is at
about 50 ohms of where I set it for a soft start.
If you want a violent start, then set it at the point where you barely press
the accelerator. This is not recommended as where if the ohms do not go
below the start up point, the motor may not shut down.
Roland
----- Original Message -----
To: <[email protected]>
Sent: Monday, September 03, 2007 8:22 AM
Subject: [EVDL] Pot Box
> I must be missing something...
> How do you turn a potentiometer through its normal 270 degrees of rotation
> with an accelerator cable connected to a lever on the pot's shaft?
> Thank you,
> Dave Delman
> 1981 Electric DeLorean Project
> ************************************** Get a sneak peek of the all-new AOL
> at
> http://discover.aol.com/memed/aolcom30tour
Roland
> Thank you,
> Dave Delman
> at
