[Cross-posted to evtech]
I tried the vacuum tube method mentioned below last night.
Charging a 6000uF cap bank from 0v to 30V with a 35V power supply took
18 seconds using both diodes in a 12x4 tube. Ten seconds elapsed before
there was any change in the capacitor voltage, probably because of the
filament warm-up time.
When I get a chance to bust out my super-dirty power supply (variac,
rectifier, capacitor), I'll test it at 150VDC, and post the results.
I bought two of the tubes, and I expect that two in parallel should give
1A total charge current, but the 10 second lag will always be there.
Lee Hart wrote (on 4/23/06):
> Neon John wrote:
>> I'm unhappy with the current practice and techniques of precharging
>> the controller caps.
> I'm using a 130v 75w light bulb as my precharge resistor. It precharges
> in a fraction of a second; far faster than the recommended 750 ohm
> resistor. Yet it still limits the current to a reasonable value.
> [snip]
> How about a really odd solution? Use a vacuum tube rectifier, like a
> 12X4. The isolated 12v filament is powered by your key switch. The
> cathode and anodes connect across your main contactor, to controller B+
> and pack+ respectively. To precharge, power the filament. A diode with
> some series resistance appears between anode and cathode, and the
> controller precharges.
