Dewey, Jody R ATC COMNAVAIRLANT, N422G5G <[email protected]> wrote:
> Depends on the "Type" of MOSFET. A Depletion Mode mosfet is already
> shorted. The source and drain sections are connected for current flow.
> You must block the current by putting an opposite current flow in on the
> gate and push the electrons out of the channel.
> An enhancement mode mosfet can be shorted, in fact, to get it to work,
> you must create a channel by applying the bias on the gate TO get it
> shorted so current can flow.
That's how they act during normal operation, not when the device is
damaged or destroyed.
All power MOSFETs used in EVs will probably be enhancement mode MOSFETs.
However, even enhancement mode MOSFETs can fail as a short circuit. In
some failures, the resulting device acts like all three pins (gate,
source, and drain) shorted together, which causes lots of problems for
the rest of the circuit. This happens when you get too much voltage,
current, or temperature, breaking the MOSFET and making it
electronically act like a short circuit, not a MOSFET.
-Morgan LaMoore
Morgan LaMoore wrote:
>When a MOSFET "blows up", it becomes a short circuit, permenantly
>conducting electricity. That means the motor negative is permenantly
>connected to the battery negative through the dead MOSFETs.
>-Morgan LaMoore
>On 9/6/07, Sarah & Erik <[email protected]> wrote:
>>When a controller fails so it acts as a short between the batteries
>>and the motor, what is actually happening? I was discussing this with
>>a fellow EVer, but I'm at a loss to understand the actual process. In
>>the case of a Curtis, there are many paralleled MOSFETs - is the
>>failure of one of these enough to act as a strong short?
>>Intuitively to me (whose practical experience with high power
>>electronics ends at the basics of how my EV works) a short across a
>>single mosfet, even if rated at 30A would blow the MOSFET before much
>>happened. Is it a cascade failure of some sort or can a single MOSFET
>>conduct well enough to cause trouble?
>>Thanks,
>>Erik
>-Morgan LaMoore
>>Thanks,
>>Erik
Semiconductors normally fail shorted. So obviously, if you have a
controller with just one or a few large transistors, and one fails, the
motor is stuck "full on". The leads on these big transistors are big
enough to carry high currents for quite a while. So the motor takes off
at full power until something else stops it (a fuse, circuit breaker,
action by the driver, etc.)
When the controller has dozens of small devices in parallel, the
situation is more complicated. You're right; if just one transistor
fails shorted, when the rest turn off, that one little device will try
to carry the entire motor current. Like a fuse, it can do so for a short
time -- a matter of seconds -- and then it explodes!
Now when it explodes, a number of things can happen. It may blow
completely open and out of the circuit, like a blown fuse. In this case,
the controller still functions, albeit with one less transistor to carry
the current. This can slightly increase the strain on the rest of the
transistors, making it more likely that one of them will soon blow, too.
If all the transistor short, and then blow open like this, you get a
"popcorn" failure. Pop... pop, pop, poppity pop. It ends up with all the
transistors exploded, and no current to the motor.
But, explosions can do lots of other things. They can throw conductive
debris into other parts of the circuit, creating shorts. They can start
fires; charring or even burning the circuit board or surrounding parts.
How the circuit behaves with random shorts or while burning is
completely unpredictable. "Stuck fully on" failures are common.
Also, when a transistor first fails shorted, it can short its gate to
its drain. This can send a command to turn all the *other* transistors
on, since all their gates are connected together. This is also a pretty
common way to get a "stuck fully on" failure.
Forget the perfect offering
