Hi,
GE took over Keystone & changed the part numbers now "GE Thermometrics" li=
ke Ecomagineering stuff. Anyway the CL-60 is now a KC006L-ND from Digi-Key=
, 10 ohms cold, .18 ohms hot 5 amps continuous. Also don't forget to put a=
diode across the coil too. I used a CL-60 on my vacuum pump on my E-Jeep =
and it ran much qieter. The Digi-Key page shows a variety of these NTC dev=
ices mainly used for inrush on switching supplies and electronic loads with=
large caps on the front end.
Have a renewable energy day,
Mark
> Subject: Emailing: P1795> Date: Fri, 19 Oct 2007 16:19:31 -0400> From: ma=
[email protected]> To:
[email protected]> > <<P1795.url>> > Th=
e message is ready to be sent with the following file or link attachments:>=
> Shortcut to: http://dkc3.digikey.com/PDF/T073/P1795.pdf> > > Note: To pr=
otect against computer viruses, e-mail programs may prevent sending or rece=
iving certain types of file attachments. Check your e-mail security setting=
s to determine how attachments are handled.
Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop =
by today.
http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=3DTXT_TAGLM_Oc=
tWLtagline
