1 - 1 of 1 Posts
I have an electric G-van (converted GM van) and it has a 216v string of 34
air-cooled STM-5-200's. I can't find any data on these on Saft's site, but
they seem similar to the 180's. They also have a large "PSA" molded into
the plastic tops across from "SAFT". I assume they were made for PSA
(Peugeot/Citroen). The "STM-5-200" is stamped into the top of the case
permanently on each battery. There is no discernable date code I can see,
but they look to be about as old as the van (1990).
Here is a crappy cell-phone pic:
http://ingineerix.com/pic/?stm-5-200
Everything seems ok with this pack, and I've done 20 miles so far without
them seeming to be near end of charge. I'll keep increasing my mileage over
time to ascertain what my real range is.
The charger that came with the van is an enormous LaMarche 60a charger,
which is microcontroller-based and seems to have been programmed for "Saft
NiCd profile" according to what is labeled on the charger.
The pack is equipped with a watering system that consists of 3 water
"loops", one loop with 12 batteries, and 2 loops with 11 in it. The 3 loops
end in some sort of catalyst block filters that I assume are responsible for
neutralizing the electrolyte should it vent too much. The beginning of the
loops have fill ports with an auto-sealing valve system.
The electrolyte level seems "normal" (up to the bottom of the caps, and the
first time I did a "maintenance" charge, a little water appeared out of each
of the catalyst filters.
I'd love to hear more about your MRE-180 watering procedure if you care to
share, as it's probably pretty close to what these need!
Thanks!
-Phil
----- Original Message -----
Sent: Wednesday, October 31, 2007 7:52 AM
Subject: Re: [EVDL] Very Disappointing Development: Batteries Won't Take
aCharge
> If you van uses Saft Nicads then the filling process is very specific,
> if not followed correctly you will overfill the batteries and on the
> next charge the electrolyte will spill from the batteries. Filling
> must me done at the end of a maintenance charge which occurs after the
> batteries have been FULLY discharged, they are then charged at a
> specific rate on a maintenance charge of a fixed amp output for a
> specific time. At the end of the charge the batteries must be filled
> within 15 minutes or you will over fill them. If you have the Saft MRE
> 180 in your car let me know and I can give you the specifics.
> Discharging the batteries to 0 resets the plates and brings the packs
> capacity pack significantly- let me know if you need help. Don't add
> any more water!
> Mark
Walt Jorgensen wrote:
>> EVDL,
>> I just joined the listserv so it won't come as a surprise that I
>> have a
>> problem. I'm trying to use the various archives and faq to discover
>> owners who have had similar experiences.
>> I have been charging and driving my /new/ TEVan for about two weeks,
>> and
>> now have had a very disappointing development.
>> I logged usage and charging from 10-15-07. Each time the charging
>> cycle
>> completed, I got a FULL+ reading on the fuel gauge.
>> I did a manual watering of the batteries with distilled water on
>> Monday,
>> the 22nd. It took 16 minutes from 1:44pm to 2:15pm.
>> Beginning on the 27th, I couldn't get past a half charge. Now it
>> won't
>> take any charge at all.
>> As you can see, I never was getting very good mileage.
>> Here is my activity log since the 22nd.
>> Date Time Odometer Fuel Gauge, Begin Activity
>> 10-22-07 1:44pm 15085 FULL+, started manual watering
>> 10-22-07 2:15pm 15085 FULL+, ended watering
>> 10-22-07 2:33pm 15085 FULL+
>> 10-22-07 5:23pm 15085 FULL+, home to Port mtg downtown
>> 10-22-07 7:48pm 15088 FULL on line, downtown to home
>> 10-23-07 3:22pm 15092 0.75, home to Smith Bldg
>> 10-23-07 5:33pm 15095 0.77, Smith Bldg to Cap Lake
>> 10-23-07 6:30pm 15096 0.77, Cap Lake to home
>> 10-23-07 6:57pm 15103 0.27 started charging
>> 10-24-07 1:02am 15103 ??? charge ended (maybe earlier)
>> 10-24-07 5:24pm 15103 FULL+, home to Morgan Stanley
>> 10-24-07 8:19pm 15106 FULL on line, Morgan Stanley to home
>> 10-24-07 8:31pm 15108 0.77, home
>> ?????????????????????? ???, started
>> charging
>> 10-25-07 12:17pm 15108 ??? charge ended (maybe earlier)
>> 10-26-07 6:49pm 15108 FULL+, home to Traditions
>> 10-26-07 9:00pm 15111 FULL+, Traditions to home
>> 10-26-07 9:15pm 15114 0.646, home
>> 10-27-07 ??? 15114 started charging
>> 10-27-07 9:30pm 15114 0.52, still charging
>> 10-27-07 ??? 15114 ???, turned charging off (I had left
>> the
>> heater & fan on)
>> 10-28-07 12:00noon 15114 0.52, started charging
>> 10-28-07 7:00pm 15114 ???, still charging
>> 10-28-07 7:03pm 15114 0.5, turned charging off (I had left the
>> radio on)
>> 10-29-07 8:27pm 15114 0.52, started charging
>> 10-30-07 1:15am 15114 ???, still charging, turned charging off
>> 10-30-07 2:30pm 15114 ZERO, started charging
>> 10-30-07 5:14pm 15114 ???, still charging
>> 10-30-07 6:40pm 15114 ZERO, still charging, turned charging off
>> Did something not work right with my manual watering? What should I
>> be
>> looking for? Any idea what might be happening?
>> As I noted before, the mileage, though not good, seemed to be
>> improving
>> and the operation, e.g., acceleration, was fine.
>> Walt Jorgensen
>> _______________________________________________
>> For subscription options, see
>> http://lists.sjsu.edu/mailman/listinfo/ev
1 - 1 of 1 Posts
