[EVDL] Sevcon Calibrator Question
2274 1
I want to thank this list and its members for helping me find a replacement
controller for my Gizmo EV. The troubleshooting steps were critical in
determining that the controller was the most likely problem.
Now that the new controller has arrived, I wasted no time in installing it. No
sparks, no fires, no blown fuses, nothing at all exciting, just the way I like
it. Having taped up all the 1/0 cables as I removed them probably helped quite a
bit too.
Upon startup, the controller displays a six flash error code which is throttle
related. The calibrator displayed a confirmation of this error, but I was not
concerned. The settings within the personality list are out of range from the
previous configuration, which is consistent with the error. I had recorded all
the controller parameters prior to disconnecting the old controller and figured
it'd be an easy matter to re-enter them and get the error(s) cleared.
Notsofast.
I'm aware of the keystroke sequences necessary to navigate the menus within the
calibrator (662/14030), but the plus and minus keys appear to be locked out:
"The calibrator can be specified to have various levels of access to certain
adjustments" is the text I found within the Sevcon PowerPak manual. I discovered
online that the 14036 calibrator has a password, but it didn't work on my model,
for obvious reasons.
Can anyone confirm that there is a password on this unit or that it's
permanently locked out from making changes to the controller? I'm thinking that
it's not permanently locked out, as I now recall that I made an adjustment to
the old controller and later made the change back.
Advice is greatly appreciated.
fred
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20100921/11971ce1/attachment.html
1 - 2 of 2 Posts
bit too.
Notsofast.
fred
___
| UNSUBSCRIBE: EV Discussion List Help
| OTHER HELP: EV Discussion List Help
Hello, how are you?
I'm having exactly the same problem... Did you solve it?
1 - 2 of 2 Posts
