[EVDL] Shunts
2203 30
Any good sources for meter shunts? What is the typical resistance for a
1000 Amp shunt?
A 1 milliOhm shunt at 1000 Amps will be dissipating 1000 watts! That seems
too high.
So 0.1 milliOhm?? Can a shunt be reasonably made??
Thank you,
Dave Delman
1981 Electric DeLorean Project
electricdelorean.com
************************************** See what's new at http://www.aol.com
1 - 20 of 31 Posts
Discussion Starter · #2 ·
In a message dated 9/17/2007 8:19:01 PM Central Daylight Time,
[email protected] writes:
1000 Amp shunt?
too high.
Thank you,
Dave Delman
A 50mv 1000 amp shunt would be 50 micro Ohms and would dissipate 50 watts at
1000 amps.
A 1000 amp 50 mv shunt is available at EVParts:
(_http://www.evparts.com/shopping/index.php?id=602_ (http://www.evparts.com/shopping/index.php?id=602)
(http://www.evparts.com) ).
Ken
On the subject of shunts, can they serve double duty? I have a shunt in line for my eMeter, could
I hook up another device (ammeter) to this without affecting the eMeter?
Dave Cover, stepping forward after my last step back
> 1000 Amp shunt?
> too high.
> Thank you,
> Dave Delman
> 1000 amps.
> Ken
.001ohms * 1000A = 1volt That is how you are getting 1000Watts
But most shunts are 50-100mv at full scale so a 1000A shunt is 1000 *
.050 or 1000 * .100 or 50-100W. peak.
You can only put that much thru the shunt for a limited amount of time.
I'd be surprised if you can get 1/2 of that on average
So you are probably only talking 25Watts or less. (Could of just not had
that second helping of cake)
Discussion Starter · #9 ·
"50mV at full scale" is common for shunts... so a 250A shunt is 0.0002
ohms. There are lower resistance shunts still.
In general you should be able to hook up a second device to the same
shunt. Do not splice into the sensing wires, just screw new ones onto
the shunt.
Danny
----- Original Message -----
Date: Monday, September 17, 2007 9:02 pm
Subject: Re: [EVDL] Shunts
To: Electric Vehicle Discussion List <[email protected]>
> eMeter?
> resistance for a
> > 1000 Amp shunt?
> That seems
> > too high.
> > Thank you,
> > Dave Delman
> 50 watts at
> > 1000 amps.
> > Ken
> http://www.aol.com>
Hi all,
I have a customer seeking a neat 75mV 500A shunt to replace one he's
not particularly happy with - searching "75mV 500A" on eBay shows you
the sort of shunt he's currently got (big nickel-plated shunts with
black vertical strips, made in China).
He'd prefer something like the Deltec shunts (more compact, with
integrated mounting block) but they only seem to come in 50mV and
100mV. Is anyone aware of any other sources I might be able to look
into? (Preferably just the shunt, since he already has the 75mV 500A
meter to suit.)
TIA,
Ian Hooper
[email protected]
Discussion Starter · #11 ·
they appears on Ebay often, i have purchased mine from here
Philippe
2008/4/28, Ian Hooper <[email protected]>:
> Hi all,
> meter to suit.)
> TIA,
> Ian Hooper
> [email protected]
> Philippe
If he has one like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250241133623
they look neat enough. Would be nice to have a non-conductive block
attached at the bottom for mounting, or how about a clear tube
(http://electroauto.com/catalog/elec.shtml#fuselink) to protect from
contact?
Ian Hooper wrote:
> Hi all,
> meter to suit.)
The easiest solution is to get a 100mv shunt, and connect a resistor in
series with the meter to drop the extra 25mv (so he gets 75mv at the meter).
Forget the perfect offering
Discussion Starter · #17 ·
Along the same vein, I picked up a shunt for the motor side of my
controller, 50mv/1000Amps. I wanted to measure the current my controller
could handle and came across a shunt first. I had been watching for a lon g
time before this option came along. The problem I'm finding is no one makes
a meter to match the shunt.
I've been watching eBay as well as the usual sources; DigiKey, Mouser,
SurplusStore, etc. I just can't find a compatible meter. I'd even go with a
50mv/100A meter, but haven't seen one. It seems all the meters in my range
work at 75mv for the top end.
Since you already have a meter, you know what shunt you need. My problem is
I can't find a meter to match my shunt. Go figure. If I'd have known how
incompatible these can be I wouldn't have jumped on it so quickly.
Dave Cover
Zeke Yewdall <[email protected]> wrote:
> I've only seen ones that are 50mV/500A and 100mV/100A (Occasionally
> 100mV/150A or 50mV/100A). I suppose you could use two of the
> 50mV/500A shunts in series, then put a 3:4 voltage divider on the
> signal to generate the 75mV/500A signal.... sort of clunky though...
> Z
> On Mon, Apr 28, 2008 at 5:39 AM, vehiculeselectriques.free.fr
> > Mine is more like this one, though for a 75mV/500A,
> > If your customer is in a hurry, i'm willing to sell it as i never
> ordered
> > the Emeter to use it with, contact me off list
> http://cgi.ebay.com/Blue-Sea-9229-Analog-Meter-Shunt-75A-50mV_W0QQitemZ120231828390QQihZ002QQcategoryZ58049QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
> > philippe
> > > Yeah that's the exact sort he's not happy with - apparently they are
> > > too big, too ugly (roughly finished), and too hard to mount (no
> > > insulating base). He's actually not the first of my customers to
> > > complain about these shunts either, oh well..
> > > -Ian
> > > >> Philippe
> from
> > > > contact?
Discussion Starter · #18 ·
You could always use a standard 50mV/500A meter, and remember that
it's only reading half of the actual amperage......
Z
> Dave Cover
> > Z
> > ordered
> > > philippe
> > > > -Ian
> > > > >> Philippe
> > from
> > > > > contact?
Discussion Starter · #19 ·
That's pretty tricky, since you'd have to know exactly how much
current the meter was drawing. I'm not familiar with the particular
one he has, but the ones I've used are very low current -- like
microamps, on the sense inputs. If the meter doesn't have seperate
sense and power inputs, the current draw could be up in the mA range,
but could also vary depending on how many digits of the display are
lit up, which won't work.
Discussion Starter · #20 ·
I think if it is analog Lee 1s correct, 1/3 the resistance of the meter in
series will the meter should do it. It's volts at this point not amps, the
current will be very low. If it is a digital meter then a resistor bridge of
two resistors will do. Something like 100 ohms and 33 ohms in series across
the shunt and then the meter across the 100 ohm resistor.
Mark Grasser
-----Original Message-----
Of Zeke Yewdall
Sent: Monday, April 28, 2008 11:49 AM
meter).
1 - 20 of 31 Posts
