21 - 31 of 31 Posts
Discussion Starter · #21 ·
I believe you can get one of these from KTA and or Electro Automotive.
---- dave cover <[email protected]> wrote:
> Along the same vein, I picked up a shunt for the motor side of my
> controller, 50mv/1000Amps. I wanted to measure the current my controller
> could handle and came across a shunt first. I had been watching for a lon g
> time before this option came along. The problem I'm finding is no one makes
> a meter to match the shunt.
> I've been watching eBay as well as the usual sources; DigiKey, Mouser,
> SurplusStore, etc. I just can't find a compatible meter. I'd even go with a
> 50mv/100A meter, but haven't seen one. It seems all the meters in my range
> work at 75mv for the top end.
> Since you already have a meter, you know what shunt you need. My problem is
> I can't find a meter to match my shunt. Go figure. If I'd have known how
> incompatible these can be I wouldn't have jumped on it so quickly.
> Dave Cover
Zeke Yewdall <[email protected]> wrote:
> > I've only seen ones that are 50mV/500A and 100mV/100A (Occasionally
> > 100mV/150A or 50mV/100A). I suppose you could use two of the
> > 50mV/500A shunts in series, then put a 3:4 voltage divider on the
> > signal to generate the 75mV/500A signal.... sort of clunky though...
> > Z
> > On Mon, Apr 28, 2008 at 5:39 AM, vehiculeselectriques.free.fr
> > > Mine is more like this one, though for a 75mV/500A,
> > > If your customer is in a hurry, i'm willing to sell it as i never
> > ordered
> > > the Emeter to use it with, contact me off list
> > http://cgi.ebay.com/Blue-Sea-9229-Analog-Meter-Shunt-75A-50mV_W0QQitemZ120231828390QQihZ002QQcategoryZ58049QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
> > > philippe
> > > 2008/4/28, Ian Hooper <[email protected]>:
> > > > Yeah that's the exact sort he's not happy with - apparently they are
> > > > too big, too ugly (roughly finished), and too hard to mount (no
> > > > insulating base). He's actually not the first of my customers to
> > > > complain about these shunts either, oh well..
> > > > -Ian
> > > > On 28/04/2008, at 6:04 PM, [email protected] wrote:
> > > > >> they appears on Ebay often, i have purchased mine from here
> > > > >> Philippe
> > > > > If he has one like this:
> > > > > http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250241133623
> > > > > they look neat enough. Would be nice to have a non-conductive block
> > > > > attached at the bottom for mounting, or how about a clear tube
> > > > > (http://electroauto.com/catalog/elec.shtml#fuselink) to protect
> > from
> > > > > contact?
> > > > > _______________________________________________
> > > > > For subscription options, see
> > > > > http://lists.sjsu.edu/mailman/listinfo/ev
Discussion Starter · #22 ·
Ah, I didn't even consider the possibility of it being an analog
meter. I just assumed it was an e-meter/link10 type device. Ooops.
I don't think the resistor bridge will work to increase the voltage --
if we wanted a lower signal voltage than what the shunt is giving, we
could use it to decrease the voltage though. Any other EE's want to
weigh in on this?
Z
Mark Grasser <[email protected]> wrote:
> I think if it is analog Lee 1s correct, 1/3 the resistance of the meter in
> series will the meter should do it. It's volts at this point not amps, the
> current will be very low. If it is a digital meter then a resistor bridge of
> two resistors will do. Something like 100 ohms and 33 ohms in series across
> the shunt and then the meter across the 100 ohm resistor.
> Mark Grasser
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Zeke Yewdall
> Sent: Monday, April 28, 2008 11:49 AM
> To: Electric Vehicle Discussion List
> Subject: Re: [EVDL] Shunts
> > The easiest solution is to get a 100mv shunt, and connect a resistor in
> > series with the meter to drop the extra 25mv (so he gets 75mv at the
> meter).
> That's pretty tricky, since you'd have to know exactly how much
> current the meter was drawing. I'm not familiar with the particular
> one he has, but the ones I've used are very low current -- like
> microamps, on the sense inputs. If the meter doesn't have seperate
> sense and power inputs, the current draw could be up in the mA range,
> but could also vary depending on how many digits of the display are
> lit up, which won't work.
Discussion Starter · #23 ·
> weigh in on this?
I guess this also depends on which question we are answering... there
are now two of them running through this thread. :)
> Z
> > Mark Grasser
> > Of Zeke Yewdall
> > meter).
Discussion Starter · #24 ·
I was responding to the question of how to use a 100mv shunt with a 75mv
meter. Either resistor method should work. The only way to use the 50mv
shunt would be to use some type of amplifier circuit. Incidentally, 1000amps
= a .1volt drop across the 100mvshunt. That 100 watts of heat. You will need
to be moving some air if you are going to do it very often.
Mark Grasser
Of Zeke Yewdall
Sent: Monday, April 28, 2008 1:01 PM
> weigh in on this?
> Z
in
the
bridge of
across
> > Mark Grasser
Behalf
> > Of Zeke Yewdall
resistor in
the
> > meter).
Discussion Starter · #25 ·
Okay. We agree :) I thought you were referring to the 50mV shunt.
yeah... that's alot of heat for a little shunt to dissipate. I've
never actually seen a shunt rated at any more than 500 amps, and those
are 50mV ones, so only 25 wattts there. But, apparently there are
bigger ones out there.
Z
> Mark Grasser
> Of Zeke Yewdall
> > weigh in on this?
> > Z
> in
> the
> bridge of
> across
> > > Mark Grasser
> Behalf
> > > Of Zeke Yewdall
> resistor in
> the
> > > meter).
Discussion Starter · #26 ·
I talked to a representative of a shunt company, and he said that the
rating listed on the shunt is the *continuous* rating, and they should
be able to handle much more peak current.
-Morgan LaMoore
> Z
> > Mark Grasser
> > Of Zeke Yewdall
> > > weigh in on this?
> > > Z
> > in
> > the
> > bridge of
> > across
> > > > Mark Grasser
> > Behalf
> > > > Of Zeke Yewdall
> > resistor in
> > the
> > > > meter).
Discussion Starter · #27 ·
Maybe his shunts, depends how they rate them. I have melted the solder out
of shunts, turned them blue, even made them blister, never more than 25%
over the rating. Of course the ones I used came from "that place".
Mark Grasser
Balyntec
Marine Products, LLC
828-581-4601
[email protected]
Of Morgan LaMoore
Sent: Monday, April 28, 2008 2:11 PM
-Morgan LaMoore
> Z
75mv
50mv
1000amps
will need
> > Mark Grasser
Behalf
> > Of Zeke Yewdall
Ooops.
we
to
> > > weigh in on this?
> > > Z
<[email protected]>
meter
> > in
amps,
> > the
resistor
> > bridge of
series
> > across
> > > > Mark Grasser
> > Behalf
> > > > Of Zeke Yewdall
> > resistor in
at
> > the
> > > > meter).
particular
seperate
range,
are
Discussion Starter · #28 ·
Take a look at this 100A meter (you have to multiply by 10):
http://www.allelectronics.com/cgi-bin/item/PMD-100A/385/100_AMP_DC_PANEL_METER_.html
They don't say how many mV it is, but they also sell a 100A 50mV shunt,
so my guess is...
- SteveS
Zeke Yewdall wrote:
> You could always use a standard 50mV/500A meter, and remember that
> it's only reading half of the actual amperage......
> Z
>> Dave Cover
>> > Z
>> > ordered
>> > > philippe
>> > > > -Ian
>> > > > >> Philippe
>> > from
>> > > > > contact?
Discussion Starter · #29 ·
50mv is a common standard shunt values. You know, you can just *buy* a
meter to match, without getting it surplus or used. Digikey and Mouser
specialize in electronics, not electrics like meters, so they aren't a
preferres source.
Try Simpson Electric Co. at http://www.simpsonelectric.com/ and look at
their analog panel meters.
Forget the perfect offering
Discussion Starter · #30 ·
>> resistor in series with the meter to drop the extra 25mv (so he
>> gets 75mv at the meter).
Analog ammeters are just a simple resistor electrically. Often, their
resistance is printed right on them. An analog ammeter marked (say) "100
amps" will in fact be a 50 millivolt full-scale meter that draws between
1 ma and 100 ma. For example, I have one with a "50 amp" scale; it's
actually 50mv full-scale and measures 18 ohms (2.77ma full scale). To
use it with a 75mv shunt, add a 9 ohm precision resistor in series.
Digital meters often have a very high input impedance (1 megohm or
more). For example, the common E-meter / Link-10 is 2 megohms input
impedance. So a simple voltage divider will work fine.
Discussion Starter · #31 ·
> that the rating listed on the shunt is the *continuous*
> rating, and they should be able to handle much more peak current.
Be aware that this will apparently depend on whose shunt you are using (and=
perhaps even on the technical knowledge of the representative you speak wi=
th ;^). Deltec shunts, for instance are not to be used at more than 2/3 of=
the rated current continuously. Fromt the Deltec website (<http://www.del=
tecco.com/>):
"Shunt Operation
For continuous operation, it is recommended that shunts are not used at mor=
e than 2/3 of the rated current under normal operation conditions. Shunts s=
hould be located in an area where freely circulating air is available. If t=
his is not possible adequate forced ventilation should be provided to keep =
the shunt operating temperature at 40=B0 - 60=B0C. Shunt temperature must b=
e maintained under 145=B0 C or a permanent change in resistance will occur."
Deltec shunts are the ones commonly used with E-meters/Link-10s. Bear in m=
ind, however, that the Deltec shunts are calibrated for +/-0.25% accuracy a=
nd it is quite possible that the permanent change in resistance that may oc=
cur due to running them at higher than intended currents may be significant=
to someone requiring the +/-0.25% accuracy and completely irrelevant for E=
Vers.
Cheers,
Roger.
21 - 31 of 31 Posts
