Yes, I have the nlg4 and I have the programing that I have been able to
hook up to my laptop and run it in a dosshell.... Im comfortable
programing it, but I don't know the proper settings.... So you are
recommending the east penns as a first choice? The current battery is a
DISCOVER battery, but I don't know what was in it previous to them....
-----Original Message-----
[email protected] [mailto:
[email protected]] On
Behalf Of David Roden (Akron OH USA)
Sent: Monday, September 24, 2007 5:44 PM
Subject: Re: [EVDL] Solectria battery question
Solectria put a fair bit of research - and a lot of cut and try - into
selecting the batteries for their EVs. In the end they settled on East
Penn
gel batteries (design licensed from Sonnenschein). Along the way they
had a
brief flirtation with Hawker Genesis batteries, which didn't work out so
well.
If your vehicle is fitted with Hawkers, it might be worth your while to
switch to East Penns. The catch is that it's more than a fitment issue.
You'll need to reprogram the charger or it'll destroy the new battery
pack
in a matter of weeks. I don't know whether Azure can still reprogram
the
older chargers - probably not.
Are you up for reprogramming the charger yourself? If you have a Brusa-
built NLG4 type charger (BC-3300, I think Solectia called them), it
should
be fairly easy with Brusa's old DOS software and a laptop you can boot
from
a DOS floppy. If it's an older BC-1000, you're probably stuck. In that
case you'll most likely have to buy a new charger and have it set up for
whatever batteries you choose.
If you currently have East Penn batteries (Deka Dominator gel) I'd
recommend
replacing with the same type. They're pretty long-lived and reliable in
this application.
You might want to join the Solectria group on Yahoo :
http://autos.groups.yahoo.com/group/solectria_ev/
David Roden
EVDL Administrator
http://www.evdl.org/
For subscription options, see http://lists.sjsu.edu/mailman/listinfo/ev
