Hello Greg,
The cable lugs connected to the stud on the low profile post will not work.
I had these type of post on my Trojans. The specs say to tighten them to
95-105 inch lbs, but at 75 inch lbs some of them started to turn and pull
out.
I found that the stud was a standard hex head bolt that was only embedded
about 1/16 to 1/8 inch below the surface of the pad.
I call the Trojan tech line and he actually said these batteries are not
design for a street type electric vehicle. The studs in the AP high post
are rated for this torque of 95-105 lbs, but these low profile post are to
be only hand tighten with the wing nut.
For a fix, I purchase all positive battery clamps that I can open up a bit
with a battery clamp spreader and install them around the 3/8 inch pad. I
want to use my battery links that had the cable lugs on them, so I purchase
from the WirthCo at www.wirthco.com the Quick Fit Gold-Plated Battery
Terminal clamps #22206 - Positive only. This clamps are a 1/2 inch narrow
band with grooves that grip this low profile post. Back in 2002, I paid
$1.75 each for them if you order a standard pack. I had to have 60 of them
for my pack of 30 batteries.
They come with a 5/16 inch stud that is actually a hex head bolt threaded in
from the bottom of this battery clamp. Instead of using the wing nut, I
install a stainless flat washer, lock washer and nut. The clamping nut and
bolt is a 10mm size. Was a little too short to get this clamp open enough
to get it over the low profile battery post, so I use a longer bolt which I
to clamp the battery clamp which press ring groves into the battery post. I
then can remove this longer bolt and install the gold plated shorter bolt.
Install these type of battery clamps, the battery clamp was about 1/8 inch
higher than the top of the battery post. So I place in a lead washer I made
by turning 1/8 inch lead wire that you can get from a fish and tackle store
which is use for making lead weights.
This lead washer went around the stud and place a stainless steel washer,
lock washer and nut on this stud. I just tighten down enough to keep the
battery clamp from slipping off. Then you can tighten the battery clamp as
hard as you want. This put addition pressure one the hex head stud, where I
can actually torque this down which puts additional battery clamp pressure
against the base of the low profile stud.
I just replace these batteries with the US-6 volt T-145's and gave them to a
guy for his EV.
You can see this type of battery clamp on the low profile post at:
http://go-ev.net/pics/016.html
Roland
----- Original Message -----
To: <[email protected]>
Sent: Saturday, September 11, 2010 11:08 AM
Subject: [EVDL] Solution to Melted battery posts - Post style
> David,
> Thanks for the feedback. I agree that the root cause is the wrong clamp
> style for the posts. Part of the problem is that I have the wrong post
> type
> for the cables I'm using. In Trojan's terminology these are Low Profile
> Terminal as found at
> http://www.trojanbattery.com/Products/terminal_types.aspx
> I made the mistake of using cables that were designed for AP terminals.
> An interesting twist on this is that I did replace the first battery that
> had a melted post. The new posts (same battery, supposedly, but different
> posts) was the Universal Terminal type. This is a much better fit for the
> cable connection, but was one of the first posts to melt after
> replacement.
> If I were to continue to use these style posts, I'd want to go with lug
> terminal connectors that would bolt on. However, I'm not confident that
> this
> would improve the situation if the posts are made of cast lead, which I
> believe they are.
> It may be worth a try if it didn't cost too much to have "a good battery
> shop" fix the bad batteries. I just don't want to spend a lot of money
> when
> I'll be laying out over $20K on a Leaf in about a year.
> I'll keep listening to the advice I receive here and look at all options.
> Greg
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On
> Behalf
> Of EVDL Administrator
> Sent: Saturday, September 11, 2010 1:22 PM
> To: Electric Vehicle Discussion List
> Subject: Re: [EVDL] Solution to Melted battery posts
> Greg,
> Your batteries aren't the best for the application, but I don't think
> that's
> the cause of your post-melting problem.
> The fact that it's always a negative post which melts is a dead giveaway.
> My guess is that all you really need to do is put the proper size clamps
> on
> the negative cables. They're probably positive-size clamps and don't make
> good contact.
> You'll also want to repair or replace the damaged batteries. If you
> haven't
> let them sit for a long time while discharged (which would cause
> sulfation),
> a good battery shop can cast new terminals onto the "stumps" and make them
> usable again.
> I'd hate to see you give up on an EV for something as minor as this.
> David Roden - Akron, Ohio, USA
> EVDL Administrator
> EVDL Information: http://www.evdl.org/help/
> Note: mail sent to "evpost" an "etpost" addresses will not
> reach me. To send a private message, please obtain my
> email address from the webpage http://www.evdl.org/help/ .
> | REPLYING: address your message to [email protected] only.
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 9.0.851 / Virus Database: 271.1.1/3126 - Release Date: 09/11/10
> 02:34:00
out.
guy for his EV.
Roland
> David,
> type
> replacement.
> this
> believe they are.
> when
> Greg
> Behalf
> Greg,
> that's
> on
> good contact.
> haven't
> sulfation),
> usable again.
> EVDL Administrator
> 02:34:00
